Battery/charging red light ON
newrider1949
Current bike(s): 1987 Voyager XII
Has liked: 21 times
Been liked: 7 times
Post by newrider1949 »
Hello all, 2 day owner here!
Charge light stays on, but when metered at battery terminals, charge voltage seems fine and rises with revs which is pretty normal. Any ideas why light stays on?
TIA
Larry
Victoria BC Canada
Has liked: 119 times
Re: Battery/charging red light ON
Hello to you Larry from Nova Scotia;
There is a single Green/Blue wire located down in the area of your turn signal relay which when the bike was new would have been connected to an electrolyte sensor located inside the battery. This sensor is/was a push fit through the top of the battery where the fill plugs go and the tip of the sensor would have been immersed in the electrolyte and the Battery light on the dashboard would not have been illuminated provided of course the electrolyte was up to/close to the full designed level.
If you do not have this sensor, and the Green/Blue wire is NOT connected to a 12Volt + source then the light WILL be illuminated.
This light does not indicate level of alternator output voltage only the level of electrolyte OR the fact that the electrolyte level sensor is not present.
If you connect the G/Bl wire to 12V+, or to a working electrolyte level sensor, then the light should be off.
Look at part 27010B of the attached parts illustration.
https://www.partzilla.com/catalog/kawas ... -equipment
newrider1949 (Thu Nov 21, 2024 8:17 pm)
Been liked: 249 times
Welcome to the forum!
I recommend attaching a Voltmeter directly to your Battery terminals, with a relay to break the connection when the key is off, and mount it where you can keep an eye on it. The Battery can die and leave you sitting, without warning!
When you first turn the bike's key on, the headlight will be off, so the Voltage reading will be accurate enough to judge the health of the Battery:
12.6 Volts+ -- good, healthy Battery;
<12.6 Volts -- Battery needs testing/possible replacing, the sooner, the better! Below 12.4 volts, it likely will not start the bike...
Also note that the OEM Alternator will not produce enough Voltage/Current, at idle, to charge the Battery -- it will drain it, keeping the bike, the lights, etc., on while idling. The engine will also run hotter if you are idling in stop-n-go traffic, leading to the radiator fan running, draining more amperage from the non-charging Battery.
Solutions/Suggestions:
1) You can have the Alternator re-wound to produce higher current output, but you still need to monitor the Battery, and this is an expensive option. :?:
2) Install an AGM Battery -- expensive, but extremely reliable, and maintenance free. :perfect10:
3) Replace most/all of your incandescent bulbs with properly fitting LED bulbs, preferably with higher Lumen output (lower wattage, higher/brighter light output). This can be a bit complicated due to polarity issues, along with color output issues (use Red LED's behind Red Lenses; use Yellow LED's behind Yellow Lenses; use white LED's in the instruments and in the Headlight, only!).
:perfect10:
4) Replace your Halogen headlight bulb with an LED replacement: Lumens can double, for a 20 Watt power savings from the headlight, alone; color/temperature can be more like Daylight (4,000-6,000 Kelvin; the higher the number, the more blue it will be, so 4,000 - 5,000 K is my personal preference), or yellowish, like Halogen bulbs (2,000 - 3,000 Kelvin, with 2,000 K being much more yellowish). Try to avoid exceeding 1,800 Lumens, as you may get ticketed for having too bright of a headlight, blinding oncoming traffic (consider a ticket a safety wake-up call before a blinded driver hits you head-on!).
By reducing the wattage consumed by your lights, by replacing incandescent bulbs with appropriate LED's, you can increase the charging voltage and amperage delivered to your Battery. By replacing all bulbs, except for the instrument cluster, with LED's, my Charging Voltage increased by more than 1 Volt, which helps, tremendously. It also frees up Watts for accessories, such as a heated vest -- keep an eye on your Voltmeter as long as you have that vest turned on! You want to ensure that the heated vest (or other accessories) does not drain your Battery, leaving you stranded on the roadside. :shock: You may want to cycle the vest on/off, to keep your Battery alive, or avoid riding when you need that heated vest running more than your bike can manage. Cheers!
newrider1949 (Mon Nov 25, 2024 5:24 pm)
newrider1949
Has liked: 21 times
Been liked: 7 times
Thanks for all the advice! Thanks to Dave,it turns out the battery sensor wire needed to be connected to a 12v source so that the red battery light on the dash went out. Did that today and all is well, alternator and battery are fine.
Thanks for the reply
Larry
These users liked newrider1949's post:
triton28 (Tue Nov 26, 2024 5:33 am)
SantaCruzer
Has liked: 3 times
Post by SantaCruzer »
Thanks for the thread.I have a wire it is green, that runs to a diode of some sort. If it is connected to 12 V the battery light is not lit. If not it is as stated in the thread. My question is what is the diode. There is very little wire coming out of it. I made an extension. My fear is the wire coming out of the diode will break. Does anyone have specifications on the diode so I can replace it. Thanks in advance for input.
Ben
If it is Worth doing ,
It is worth doing twice.
SantaCruzer;
not to worry about that resistor because if you follow that electrolyte sensor wire into the main harness, down by the flasher unit you will find where it meets up and connects to the main harness. As a side note the wire should be Green/Blue although it is hard to see the Blue colour tracer.
Even if all you had was that bullet terminal from the main harness, if one was to extend that to 12V + without the resistor and sensor that would work to keep the Battery light from illuminating.
You will be OK with what you have so long as the G/Bl wire goes to 12V+ in one way or another, resistor or not.
If it is in fact, a diode, it is just to protect the wire from conducting reverse voltage: diodes allow current to flow in one direction, only, while a resistor does not care about polarity.
Diodes are two-lead devices, not three. If you have a third lead from it, then it is not a Diode, but rather a Transistor, or some other solid-state device. If you can see an ID code (1N4007, is a Diode ID code, for example, or 2N3024 is a Transistor ID code), you can look it up on the Internet to see what type of device it is.
If you only use two leads on a Bi-polar Junction Transistor, you have a Diode (not a good idea, as the Base of a BJT is not designed to pass much current, unless you are using a large Power Transistor, say a 2N3055). If someone wanted to protect against reverse polarity, and all they had was a BJT at hand, they could have used two of its leads (Base-Emitter, or Base-Collector; Collector-Emitter won't work...), knowing that minimal current would pass through it. Really, it sounds like a cobble job which was totally unnecessary -- see below.
As long as you connect said wire to +12 Volts, like the positive battery terminal, you won't have any issues -- a Diode is unnecessary, but it won't harm anything, either. Cheers!
