Compression
- sammyfranziska
- 1
- Current bike(s): 1984 voyager zn1300
Compression
Hi im in the process of rebuilding the engine on my 86 and have ran into an issue trying to get compression. I rebuilt the head and by every measure in the manuals i have it correct and the timing correct on the bike yet im only getting 40-60 lbs compression on each cylinder i did a leak down test and it passed at 90lbs ao im scratching my head as to what could be wrong any advice would be great
- Has liked: 242 times
- Been liked: 631 times
Re: Compression
It's difficult to get a good compression reading on these bikes. That's the best I can offer from what you said.
- sammyfranziska
- 1
Re: Compression
Ouch is there any tricks to getting a better cold measurement? Id rather not button the engine up without being damn sure its correct
- These users liked sammyfranziska's post:
- ted1r (Fri Jan 10, 2025 10:33 am)
Re: Compression
I wouldn't expect much higher than that, cold -- especially if unseated rings. I think you'll need to put it back together and test it warm. What else are you going to do now anyway?
Starting it to warm it up is the best part of a rebuild. You just never know --- but it usually turns out great.
Like they say, life is like a jar of jalapenos: what you do today might burn your ass tomorrow.
[edit: I misread your post and thought you were getting 90lbs cold. It won't start with just 60lbs. My bad. I still suspect a faulty test. Are you using an threaded extension tube -- the push-in expansion units probably won't get it with these deep wells.]
- Van Voyager
- Has liked: 52 times
- Been liked: 44 times
Re: Compression
At the risk of asking a dumb question: are you holding the throttle WFO while performing the test?
- Has liked: 505 times
Re: Compression
I presume you're using a compression tester with threads, rather than the push-in kind?
