Got my sockets from Autozone. Dont' have the number handy, sorry. You can print the pictures and take it with you.
Solder the ground wire to the socket, since it doesn't have one.
Cut notches in the housing for the tabs to lock into.
Cut the notches to fit the "V" shape of the tabs. Minor detail, but it'll bite a little more, and keep the sockets locked in a little better.
With the sockets in and wired up there is a bunch of wires....
....that have to fit in between the fender and the light housing. I complicated it even more by putting some connectors in there so I could remove the light assembly without having to cut wires.
You should have molded-in clips on the back of the fender that you can run the wires through. I heat shrinked the entire run of wires for more protection. Electrical tape, small convoluted tubing, etc. will work as well.
There is a rubber plug at the top of the fender. Cut a hole and run the wires through it. I used an aftermarket connector since the connector on my bike had been wacked off. So, I just got a matching male and female set.
The bulbs will not go through the holes in the housing. You have to put the sockets into the housing, then the bulbs into the sockets. One of the guys had mentioned a Honda bulb that fit the 1157 socket but had a small enough glass that it would pass through the housing's holes. Also, since the sockets are cheaply made, one of the first ones I got, had different length tabs than the other. They wouldn't go past the housing far enough for the tabs to "lock" into the plastic.
After running this setup for a long while, I switched the bulbs over to the 24 LED (18 + 6 radially mounted) for cooler operation, as well as, line the black plastic with foil for reflectivity. Did the same for my old trailer as well.
Chris
