#1 – Turn the bag & the cover inside out
#2 – Locate a vertical seam on the rear of the cover by the top trunk
#3 - Sewing along a vertical seam in the bag, to a vertical seam on the cover, sew the inside-out bag upside-down (the opening down), so that the bag opening is just a bit above the bottom edge of the cover. (Don’t forget to lock-stitch the seam)
Bingo bango bongo – you’re done. Now when you put the cover on your bike, the bag will be hidden inside the cover, by the top trunk, and you’ll always have it. To store the cover back into the bag, pull the front of the cover over the windshield, and then begin at the top-trunk, stuffing the cover into the bag as you now turn it right-side out.
