Fork Seal Removal
- Current bike(s): 1982 Moto Guzzi V1000G5
1980 Yamaha XS850 - Has liked: 0
Fork Seal Removal
Sorry for the noob question, but since I just broke the connection tube by being ham fisted, I think I will ask this first. I have the forks out and have removed the dust cap and circle clip adjacent to the fork seal, but the fork seals wont budge when I pull on the upper fork tube. Is there a trick or are they just stubborn? The spring replacement faq does not address this. TIA
- Rhinestone Kawboy
1970 Honda CL350 Scrambler
Re: Fork Seal Removal
I believe you have to have the lower fork Allen bolt removed in order for that to work. If you have the Carl Leo DVD on front fork maintenance (available on AVA Merchandise page or Gift Shop), it covers front fork dis-assembly and re-assembly.
Iron Butt Member #47339
- gearheadfla
1989 Voyager XII
2007 Vulcan Nomad
I just finished doing this job today. Just to see if I could I changed the seal without removing the springs. I took a flat bladed screw driver that was not quite as wide as the seal, put it across the seal and drove it with a rubber mallet until the seal was cut in half. It popped right out. Then I oiled the new seal up real good, slid it down the shaft and carefully tapped around the seal with a new unsharpened pencil and my mallet. Make sure the seal goes down even all the way around. That being said, I did remove the spring to change the oil, I just wanted to see if it could be done. This fork was leaking so bad that oil was covering my lower fairing after no more than 2 miles. Just got back from a test ride and I did get into it hard, not a drop of oil was to be seen. Btw , man are these bike fast.
Jim in Fl. 88 XII
89 XII-parts bike-scraped
01 XII-sold
07 Vulcan Nomad
Patriot Guard Rider, Florida.
Sunshine State Voyagers
01 XII-sold
07 Vulcan Nomad
