fuel problem
rob
Current bike(s): Kawasaki 1700 2009 .BMW K1200lt
fuel problem
Post by rob »
hi guys.Im having a problem,the bike ( voyager)seems to be starving for fuel. I dont seem to have the power, at 2400rpm.I loose power,the bike seems that it is starving for fuel.It was doing it before the new E.C.U. was fitted. Anyway maybe one of you guys have had this problem. Rob from Australia. :pray:
Turbo4x4
Re: fuel problem
Post by Turbo4x4 »
Rob,
That's one I would take back to the dealer for resolution. As long as it's under warranty, let the dealer figure out what's wrong. To easy to screw up sensetive electronics, and then the expense is on you. Just my opinion.
Turbo4x4
David (N. Alabama)
2014 Triumph Trophy SE
Re: fuel problem
Post by David (N. Alabama) »
Is the bike completely stock? If so, you may have gotten a bad batch a fuel and now things are gummed up some. If you don't have an idea of any situation where you may have caused the problem then you should get it into the dealer and let them sort it out.
rob
Re: fuel problem
Post by rob »
Thanks Guys, It is booked in next Monday at dealer.Keep you in touch on what they find.ROB
rob
Re: fuel problem
Post by rob »
Hi Guys, Going to Canberra tommorow to pick up bike.After two days with the dealer,computer giving wrong faults.Finally it was the fuel pump.lets hope is O.K.
Killroid
Current bike(s): 2009 Kawasaki Voyager 1700
Candy Plasma Blue / Metallic Diablo Black
Re: fuel problem
Post by Killroid »
Hmm...I've noticed that mine is only getting around 30 mpg, if that
ASH
2009 Voyager 1700 - Candy Plasma Blue/Metallic Diablo Black
Named "Dori"
David (N. Alabama)
Re: fuel problem
Killroid wrote:Hmm...I've noticed that mine is only getting around 30 mpg, if that
Is this after getting the replacement ECU? If so, you should contact your dealer. Kawasaki has admitted that a few reprogrammed ones might not be right and you should get a new one.
