Gas milage
Danh
Current bike(s): 1700voyager
Gas milage
Post by Danh »
Last fall I had the new ecu installed and today got my first extended ride in.
36.5 mpg calculated, 38.5 on the meter.
Needless to say I am disappointed with that for gas milage.
Dan
David (N. Alabama)
2014 Triumph Trophy SE
Re: Gas milage
Post by David (N. Alabama) »
Danh wrote:Last fall I had the new ecu installed and today got my first extended ride in.
Dan
Dan, I ran 10 tanks of fuel through my bike recently and my lowest MPG was 32 and my highest was 45. I calculated the average at 39 MPG and my meter read 38.9 after running those 10 tanks of fuel.
I am pretty happy with that considering my KLR 650 averages 45 MPG, My Ninja 650 50 MPG, and my Mean Streak 42 MPG.
What kind of mileage were you expecting out of a 1700cc fully faired, 900+ lb motorcycle?
I just wish it had one more gallon so I could go 200 miles before looking for fuel.
Was it a calm day, flat roads, and 55 MPH riding?
goose
Re: Gas milage
Post by goose »
Dan
BINGO
Voyager
Re: Gas milage
Post by Voyager »
Dan
I would be disappointed also, but this seems the norm for a heavy cruiser-style bike. The big V-twins just don't have the efficiency of the smaller, in-line 4s. And I don't think they have the aerodynamics of the sport touring bikes which hurts a lot at higher speeds.
Are you using ethanol poisoned gasoline? That hurts a lot also. My 1200LT has lost 3 MPG since the poison was added to the local gas.
2007 K1200LT, VOICE II, Navigator V, Motorrad Communicator
Danh
Re: Gas milage
Post by Danh »
Yes on the poison gas.
My comment on the milage is with the first ecu I was getting 40 to 42mpg
Dan
David (N. Alabama)
Re: Gas milage
Danh wrote:Yes on the poison gas.
Dan
Keep track of at least several tanks of fuel. When I first got the new ECU it appeared that my mileage had dropped some but now with over 7000 miles on the new ECU it looks like it is back close to the same. Maybe 1 mpg less. Of course with the cost of fuel increasing I am finding myself mixing 93 and 89 octane fuel if I add fuel before running it down to almost empty. If almost empty I put in 93.
I recently found one station near work that has no ethanol so I am going to try and buy several tanks of fuel there and see if that changes my findings.
1700Guy
1982 Honda 500 Silverwing
1981 Honda CB900C
Re: Gas milage
Post by 1700Guy »
I also lost my gas milage when they I installed the new reprogramed ecu. I went down to about 35-36 about the same as alot of the 2009s were getting new. The shop had a new ecu on hand for a new Voyager still in the crate I put in the new ecu and I got my gas milage back. I get about 39-40 in town and 42-44 out of town at about 55-60 mph. I can not say that I did not get any if not much better than that on my 1200. But one thing that I will add is if you get on the thottle on the 1700 which is very enjoyable and I seam to do that more on the 1700 than I did on the 1200 I might add you are going to suck up more dinosaur remains.
1st one
Current bike(s): 2009 Kawasaki Vulcan Voyager
Re: Gas milage
Post by 1st one »
I made an appointment yesterday to get my ECU swapped out. I have 34000 km (21000) miles on my 2009 Voyager . My wife and I have been on two long trips the latest being too Rapid City SD and area.This trip along with the other one, averaged 42.2 (mpg Can) at the pumps. Speeds were up to 120km (74mph) with cruise on. Both trips were each just over 3100 km (1900 miles) My Bike has never stalled other than once near Mt Rushmore it idled down to 500 rpm I quickly caught it before it stalled I suspect the difference in altitude may have caused this. Any ways if I don,t change it the dealer will do it anyways as Kawi has deemed it as a safety issue.
__________________
Then your not riding enough
2009 Voyager
1st One
David (N. Alabama)
Re: Gas milage
Duane Ash wrote:I also lost my gas milage when they I installed the new reprogramed ecu. I went down to about 35-36 about the same as alot of the 2009s were getting new. The shop had a new ecu on hand for a new Voyager still in the crate I put in the new ecu and I got my gas milage back. I get about 39-40 in town and 42-44 out of town at about 55-60 mph. I can not say that I did not get any if not much better than that on my 1200. But one thing that I will add is if you get on the thottle on the 1700 which is very enjoyable and I seam to do that more on the 1700 than I did on the 1200 I might add you are going to suck up more dinosaur remains.
Duane Ash
AVA Chairman
There seems to be a difference between the reprogrammed ones and the new ones. I got a jump start on the recall so I got a new ECU instead of a reprogrammed one last fall. Makes you wonder if there is something other than software that is different.
Beetle 66
Current bike(s): 2009 voyager 1700
1990 Voyager 1200
Re: Gas milage
Post by Beetle 66 »
How do you know if you have a reprogrammed or a new ecu.
Is there away to tell the differents
David (N. Alabama)
Re: Gas milage
Beetle 66 wrote:How do you know if you have a reprogrammed or a new ecu.
Yes. Different part number. Below is a post I made back in November.
David (N. Alabama) wrote:Update: Called Kawasaki Customer Service. He said that new units are the 99999-0316 for the Nomad/Voyager, and 99999-0321 are reprogrammed units for the Nomad/Voyager.
alta drifter
Current bike(s): 2009 Kawasaki Voyager
Re: Gas milage
Post by alta drifter »
the part number on mine is 21175-0721 and my dealer told me he thinks it is a new one ( my bike was sold in canada if that makes any difference)
mustang64
Re: Gas milage
Post by mustang64 »
http://pure-gas.org/
Real gas - real mileage...
Voyager
Re: Gas milage
Post by Voyager »
mustang64 wrote:http://pure-gas.org/
Unfortunately, none with a hundred miles of where I live. I've had to resort to paying more than $5/gallon for avgas just to avoid ruining my chain saw and lawn mowers.
TheAudiDoc
2009 VV1700 SOLD
Re: Gas milage
Post by TheAudiDoc »
want to improve mileage.... put on a 10" windshield....2-3 mpg improvement....i ran 100 miles saturday....mostly 2 lane country roads......42.8 mpg :thmup:
Work hard.....Ride Harder!
Mike Pisarski , Tecumseh, MI
It's A U D I
Danh
Re: Gas milage
Post by Danh »
How was the head buffeting? Just curious as on a long trip it can get tiring.
dan
TheAudiDoc
2009 VV1700 SOLD
Re: Gas milage
it was hard to tell...it was very windy sat. when i took it out with the new windshield...if it ever stops raining i will report back on a normal ride...
It's A U D I
David (N. Alabama)
Re: Gas milage
TheAudiDoc wrote:want to improve mileage.... put on a 10" windshield....2-3 mpg improvement....i ran 100 miles saturday....mostly 2 lane country roads......42.8 mpg :thmup:
I just put the 4" shorter Dark Tint shield from Rifle. With the gel seat and the sheepskin on the bike I can see over the windshield the ground in front of me 30 feet away. The wind just hits the top of my helmet. Hopefully enough to put some air into the vents. I really like it. Now with 3 shields to swap between I should be covered for anything.
Now to practice pulling the trunk for local riding so I won't be wishing for a Vaquero. :lol:
TheAudiDoc
2009 VV1700 SOLD
Re: Gas milage
David, i just got the sweetest deal in town....a Vaquero to ride any time i want to....My brother bought one and flipped me a set of keys....... can u say SWEEEEEET :thewave: .....best part is it sits in my garage next to the Voyager!
please don't hate me
It's A U D I
David (N. Alabama)
Re: Gas milage
TheAudiDoc wrote:David, i just got the sweetest deal in town....a Vaquero to ride any time i want to....My brother bought one and flipped me a set of keys....... can u say SWEEEEEET :thewave: .....best part is it sits in my garage next to the Voyager!
I don't hate you. Just jealous! :gig:
You will have to provide some insight on the differences and similarities of the way the two bikes ride and handle.
