Does anyone have a suggestion on how to deal with the turn signal self cancel that works intermittently? I don't know where to start looking. Bike is a 2002 Voyager XII
Ghost
Dumb question of the day
- David (N. Alabama)
Re: Dumb question of the day
Hello Ghost. Welcome to the forums. There are no dumb questions. There have been many discussions on this topic in the forum. You might want to use the search function near the top right section of the web page.Ghost wrote:Does anyone have a suggestion on how to deal with the turn signal self cancel that works intermittently? I don't know where to start looking. Bike is a 2002 Voyager XII
Ghost
Anyway, intermittently working self cancel probably points to corrosion somewhere in the circuitry. If you have a service manual you might want to start by finding all the connections that go to the turn signal switch and disconnect, clean, grease and put them back together.
Did the bike get a lot of use in the rain? Or washed where spray got in the electronics?
So, if the search doesn't work for you, I'm sure someone who has been through this will point out what they found to be the culprit in their case.
- forplay
- Current bike(s): 2002 Honda Goldwing GL1800
I had a problem with the left turn signal not cancelling all the time. I spoke with Carl and he had me take the 2 phillips head screws out from under your left grip. It works like a clam shell. When you take the turn signal switch apart, clean it with contact cleaner. Work it back and forth. Then use WD-40 and lube the same switch. Work it back and forth, mine now works great. Very easy fix!
Keith
Keith
Keep the shiny side up
- usmalenurse
- Has liked: 7 times
- Been liked: 41 times
That took care of my issues as well.forplay wrote:I had a problem with the left turn signal not cancelling all the time. I spoke with Carl and he had me take the 2 phillips head screws out from under your left grip. It works like a clam shell. When you take the turn signal switch apart, clean it with contact cleaner. Work it back and forth. Then use WD-40 and lube the same switch. Work it back and forth, mine now works great. Very easy fix!![]()
Keith
- These users liked usmalenurse's post:
- T10gator (Fri Mar 10, 2023 1:19 am)
Charles Hairr
1997 Voyager XII
2016 Honda Goldwing
1997 Voyager XII
2016 Honda Goldwing
- gearheadfla
1989 Voyager XII
2007 Vulcan Nomad
I wish mine didn't work sometimes.
Jim in Fl. 88 XII
89 XII-parts bike-scraped
01 XII-sold
07 Vulcan Nomad
Patriot Guard Rider, Florida.
Sunshine State Voyagers
01 XII-sold
07 Vulcan Nomad
