My temp gauge is not working, but if I ground the wire to the engine, as per the FSM, it deflects from C, to H, as it should. In the Tech Tips booklet, it discusses adding a better ground connection to the sensor assembly(?). No photo's, no real help. Sorry, folks, but I cannot see the sensor, even after removing the complete fairing. I have traced the Y/W wire -- as mentioned before, I used it to perform the gauge test; I cannot follow it to the sensor, itself, no idea where to attach a ground wire on the sensor assembly. Can anyone shed some light on this problem?
We were supposed to leave for three days, tomorrow, but I don't care to ride it without seeing the temp gauge showing me what the engine is doing. Not certain the fan switch is working, either, so knowing the coolant temperature is critical, as always. Cheers!
