progressive springs
Lucasind
and a bunch of parts !
Has liked: 203 times
Been liked: 72 times
progressive springs
Post by Lucasind »
:?: Maybe this has been discussed before.... but everyone is talking about how much better their ride is with p-springs ... in what way ? harder.. softer... better cornering... braking control... please post your observations and where to get them...... I don't have a problem with my 03... but anything could always be better !! tony
gearheadfla
1989 Voyager XII
2007 Vulcan Nomad
2006 Honda Rebel
Re: progressive springs
Post by gearheadfla »
Better handling, a lot less dive when braking. They way they work is at normal riding and roads they have the same spring rate as you do now, when you ride a little harder they react more firmly. Depending what weight fork oil you refill with, you will get different rides, I used 15wt oil because I ride two up most time and I weigh 280, it's pretty firm now, I'm thinking about going down to 10wt, some use transmission fluid (about 7wt) so it depends what you want, big advantage is NO MORE AIR worries, and like I said, a lot less dive when braking. Good upgrade. :thmup: And I like the way it handles, I've been known to really dive into the turns when I get a wild hair and the bike seems to like it too.
Jim in Fl. 88 XII
89 XII-parts bike-scraped
01 XII-sold
07 Vulcan Nomad
Patriot Guard Rider, Florida.
Sunshine State Voyagers
Trust us, go with progressives all around. You'll never look back!
debron
Post by debron »
.....Firmer, but smoother ride, less dive when braking, just feels more solid....
Air Force
Current bike(s): 2003 Voyager xii
2000 Voyager xii
2000 Voyager xii
1988 Voyager xii
1977 Suzuki GT500B
2000 Escapade Cargo Trailer
2001 Escapade Cargo Trailer
2009 Kompact Kamp Cargo Trailer
Been liked: 6 times
Post by Air Force »
What Mr Jensee said!
gearheadfla
1989 Voyager XII
2007 Vulcan Nomad
2006 Honda Rebel
Ordered my rears today, can't wait to rip the air lines right out of the bike. :hpdc:
Jim in Fl. 88 XII
01 XII-sold
07 Vulcan Nomad
Lucasind
Post by Lucasind »
gearheadfla wrote:Ordered my rears today, can't wait to rip the air lines right out of the bike. :hpdc:
All right,, what brand did you order,... and where did you order them from ?? oh yeah... where did you order your front p-springs from also.. tony
gearheadfla
1989 Voyager XII
2007 Vulcan Nomad
2006 Honda Rebel
I got my fronts from Carl Leo last year, I ordered Progressive 412's with heavy duty springs (we ride 2 up most the time) off E-Bay for $221.03 and free shipping. I will find the ad on E-Bay and will try to post here in a bit.
Here is the link http://www.ebay.com/itm/New-Progressive ... 27&vxp=mtr
I also found a NEW front light bar for the crash bars. :thmup:
Jim in Fl. 88 XII
01 XII-sold
07 Vulcan Nomad
Markus56
Current bike(s): 2002 Kawasaki Voyager
2-1987 Kawasaki ZL1000
2-1985 Kawasaki ZL900 Eliminators
1985 GL1200 Honda Goldwing
Post by Markus56 »
I just did this upgrade two weeks ago with 15W oil on Carl's recommendation and it made all the difference in my '02 Voyager XII. Mine were sagged out and would bottom out easily........now it's never felt so good! :hpdc: My bike has less that 10,000 miles still so it wasn't from millage, it's the junk springs these bikes were born with is the problem (just like a lot of other Kawasaki motorcycles I've got or had). Thanks Carl for guiding me through the rebuild on my forks, your expertise is greatly appreciated and was very helpful. :bravo: He also happens to be an excellent source for any parts you may need! Thanks again Carl.....you da' man! :thmup:
wyofisher
Current bike(s): 1986 Kawasaki Voyager XII
Post by wyofisher »
Its all you guys' fault. I just upgraded to progressives all around, and love it. Of course it does help make them look good when all 4 shocks are worn out.
So new progressives springs and rear shocks, new fork seals and bushings, new steering head bearings, new swing arm bearings, new rear wheel bearings, greased drive shaft, new rear tire, and new oil all around. Yeah, I had neglected the bike, I'm not proud of that. Rides better than ever, smother and quieter, like its on rails. Thanks to the suggestions of all on these forums.
Lucasind
Post by Lucasind »
All right..!! sounds like ur bike is ready to ROLL.... see ya at the rally !! :gig: :clap:
dmwoost
Current bike(s): 1997 Kawasaki Voyager XII
1982 Suzuki GS 850 GL
Post by dmwoost »
I am changing the front springs out, the question is on Oil. The only single wt oil I can find is 30Wt is there any issue using a multi grade? What other options?
Tat2demon
Current bike(s): 78 Yamaha XS 1100
81 Yamaha XJ650
88 Kawasaki Voyager XII
Post by Tat2demon »
You need to find Fork Oil. Should be sold at most every motorcycle shop.
Nate
78 Yamaha XS 1100
81 Yamaha XJ650
Been liked: 249 times
Fork Oil is a specific product, usually available only from shops/dealers. As an alternative, you can use Dexron III (conventional)/VI (Full Synthetic) ATF fluid, which clocks in at ~8 Weight; Fork Oils come in 5, 7, 10, and 15 Weight, if I remember right. The ATF sells for around $4-$8 per quart; the Fork Oil sells for around $15 per quart. Both last the same time, so it is more about the weight, and the cost. Cheers!
Bruce in OK
Current bike(s): '01 VXII
'06 Vespa GTS 250
'02 Honda Elite 80
'99 Honda CB 250 Nighthawk
Post by Bruce in OK »
You don't want to use motor oil in your forks. What weight you should use is dependent on your riding tastes (how firm you like the suspension), your riding habits (such as riding two up or with the bike heavily loaded most of the time), your riding style (aggressive or sedate), and even your environment (average ambient temps, etc.). All of this is subjective and you may wish to experiment a little.
That being said, my perception is most opt for heavier weight oil with 12 or 15 wt. the most popular.
Bruce in OK
