gearheadfla wrote:
The 86 stands alone without cruise or rear speakers, 87 and after went pretty much unchanged other than color through the whole run of XII's, I think there was a clutch spring made in the 90's, Maw Kaw got it right the first time and just went with it.
Give Carl Leo a call. He can talk you through a fix to your issue.
I will learn this "year breakdown", just as I did with the KLR...different years, few changes here & there, but Maw Kaw got it right the first time...that would be a first!
This Carl guy must not mind getting phone calls, but I really hate to bug him...sounds like a heck of a nice guy though!?
Due to being moved to "day shift" for this week only, while the kids are on Spring Break, my body is used to the "swing shift" I normally do, so I didn't get to much done on the XII...well, I tried Meguiar's Plastic scratch remover on the windshield, but it didn't do much. I removed the lower, tinted windshield from the running bike when I swapped engines, I didn't like it and went with my "donor" windshield from the "totaled" 2000 and that's where the scratches came from. I think as I delve into this Cruise Control issue, I will remove the stickers on the stock windshield that came on the running 2000 and install it. I did manage to get a little wax on most of her though!
As for the cruise control issue, because I was a bit tired and I would have to pull the phoney gas tank and air box again, I did the former and had to go do some much needed paper work...NO NO, forms RE: doctor bills and stuff like that...SCHEESH!
I did notice when I took the "slack" out of the throttle cables(accel/decell) @ the carbs, according to the Supp manual, I tightened them too much, so I will start there and work back toward the unit under the starboard fairing someone mentioned previously. I think it's an easy fix and from what you guys are saying and how the speed drops as you guys said, I'm thinking I just might have an "improperly" adjusted cable...now I just got to find it?
It is odd though, I try the cruise as soon as I get going on the HWY and it kicks off 2-3 times before I wait awhile, almost like it needs to heat something up first?
But I think it's just having to work to hard with a cable or two and it shuts off.
Thanks for the input...I'll keep you informed.
