For my fellow "hams" with Voyagers.
k7nutN7nut
Current bike(s): 1987 KLR 650
2000 Kawasaki Voyager XII
'00 & '86 Voyager's(parts)
1969 Honda CT90
1985 Honda TRX 125
Post by k7nutN7nut »
After selling off the first of two Clarion 9090V Audio systems for my '00 V XII, I needed to figure out how to mount my Yaesu FTM-10SR in the slot where the Clarion currently is!?
There's no point in leaving the stock audio system on my bike, since the Yaesu does what the Clarion does...but MORE!
So I used my "spare" dash and radio hole to figure out "how" this was going to work?
So, this is what I have come up with so far. The radio is to small to take up the entire slot, so I needed a "cover", so anyone coming up to the bike couldn't just, reach in there! After a tip from a member here about access to the speedo cable through the headlight hole, I came up with this plastic cover design, with the nut on the backside.
I still have to weld up my spare antenna mount to put the Larsen 2/70 coil 12" higher than the stock antenna base, then, pull everything apart!
Even having said this, i ran into a friend in town yesterday, he has an '09 KLR 650 and he own/operates 6 repeaters in the area, but he said he wants to mount a dual band radio on his KLR. I may be giving up my FTM-10SR for an FTM-10R, because I don't need to worry about space on the Voyager, like he does on the KLR.
But, will see. Sooooooooo...this is what I've got so far.
The face is just "resting" on that rag and would be "mounted" on the plastic cover once in place...obviously, since the gauge cluster of course goes there!?
1987 KLR 650
'00 Voyager XII
Has liked: 95 times
Been liked: 155 times
Re: For my fellow "hams" with Voyagers.
Looks like you've freed up enough room for a volt meter and/or 12v power outlet in the extra space if you wanted.
k7nutN7nut
1969 Honda CT90
1985 Honda TRX 125
Your right, never thought that far?
However, there is a "cigarette" plug under the flap below the "fader" now on the port side, put there by the PO. But, who says I can't move it and, I think I like the volt meter idea!? :hmm:
1987 KLR 650
'00 Voyager XII
So, where is this control head going? I am trying to visualize your concept. I've done stuff like this in the past in a 73 Vega and and a 75 Firebird. Just wondering....
k7nutN7nut
1969 Honda CT90
1985 Honda TRX 125
Mr Jensee wrote:So, where is this control head going? I am trying to visualize your concept. I've done stuff like this in the past in a 73 Vega and and a 75 Firebird. Just wondering....
Right on that plastic "cover plate" in front of the CPU, I'll drill a hole/notch on the bottom for the wire to pass through and mount the face plate clip. Basically the FTM face will be where the tape deck is now on the Clarion.
1987 KLR 650
'00 Voyager XII
