Off idle stumble
96desertXII
Off idle stumble
Post by 96desertXII »
I'm pretty sure my XII is a california model and I have a HORRIBLE off idle stumble. In fact at 2500 rpm and below the engine stumbles with any small throttle changes, big changes are ok, but little ones suck.
Any "fixes" for it? Its just an irritant for me and I would like a smoother throttle response.
Chuck & Ruthie
1996 Voyager XII (89K and climbing)
1989 FLHS (sold)
2009 FLHTCI (sold)
2005 FLHRI (sold)
2003 FLHTCU (sold)
1978 GL1000 (sold)
1978 CB750K (sold)
1958 FLH (stolen)
mountainman
Current bike(s): 2012 Honda Goldwing GL1800 L2
Re: Off idle stumble
Post by mountainman »
Well that's a tough one cause these things seem pretty lean off idle to me. Assuming there's no dirt or gunk in pilot circuit, you can open pilot screws some and gain a tiny bit there. It will help some but it really just masks over the real problem. Which is pilot jets need enlarged slightly.
Make sure your carbs are clean by running a couple tank gas with seafoam cleaner. Experiment with pilot screw enriching and see if it makes it better for ya. If you go to far rich with pilot screws it will smell rich at exhaust at idle. good luck! let us know what you find.
1982 Suzuki GS750TZ (sold)
1977 Kawasaki KZ650 (sold)
1974 Kawasaki KZ400 (sold)
Kevin B in Illinois
1990 Kawasaki Voyager XII
2009 Kawasaki Vulcan Voyager
1969 Kawasaki Sidewinder 250
1965 Kawasaki F2TR 175
2006 Suzuki DL1000
Post by Kevin B in Illinois »
Also check the vacuum hose between the ignitor and the carbs. If it is pinched or collasped it can cause a low speed stumble (mine did this and drove me nuts for a while til I discovered it).
Kevin Braddy
IPVMC
President
AVA Bike Games Winner
Solo Bowling Green Rally
Two up Red River Rally
Two up Durango Rally
Two up DeGray Rally
Runner up Bike Games
Solo Boone NC Rally
Two up Boone NC Rally
Two up Bowling Green Rally
96desertXII
Thanks..........I will check the hose, she does have 88K on her.
I will most likely rebuild the carbs this winter and get those in line. I read something about a 3mm washer under the needle helps too.
Chuck & Ruthie
1989 FLHS (sold)
2009 FLHTCI (sold)
2005 FLHRI (sold)
2003 FLHTCU (sold)
1978 GL1000 (sold)
1978 CB750K (sold)
1958 FLH (stolen)
