I was reluctant to make this purchase because a couple of returning NorCal members from the Logan AVA Natl. rally said their helmets were too heavy-the heaviest on the market they exclaimed. I needed a helmet but did not want to spend upwards of 600-800 for a nice Shoei Neotec modular helmet.
So, I went to the local motorcycle shop which isn't so local to compare helmets. I wasn't even going to look at the Shark helmet for the before mentioned reason, but found the helmet to be revised to a lighter weight 200 grams less then its predecessor. I found the weight to be comparable to the other modular helmets, and the price was in between the Nolan, Shoei Multitec and the Neotec price range.
I found the optics on the Shark Evo 3 Series to be easier on the eyes than the Nolan, and the weight I believed was going to be lighter than the NorCal members eariler Series 2 helmet, so I did some research.
The webBikeWorld.com site is and was a terrific resource for me when considering my final purchase. I think anyone looking for a helmet should consider this source b4 purchasing a helmet. You can drill down pretty deep and find the the shape helmet by face shape or by weight.
http://www.webbikeworld.com/motorcycle- ... elmets.htm
This was the review for the Series 2 which is 200 grams heavier, but you get the idea.
http://www.webbikeworld.com/r2/motorcyc ... k-evoline/
and this is the link for modular weight comparisons
http://www.webbikeworld.com/motorcycle- ... tm#flip-up
The Shark is a DOT & ECE rated helmet, designed in France and mfg'd unfortunately in China, under Shark's close supervision so I'm told. I probally lost a lot of you when I mentioned France and China. Intitally I thought the helmet was made in England. Oh well. If you're still interested read on.
In a size large the pre-2012 is heavy. It came in at 1920 grams or 4.23 lbs., so the one I'm wearing is 1720 grams 3.79 lbs. And honestly out of the box, it doesn't feel too much heavier than my Shoei RJ Platinum Air, which weighs 1378 grams 3.037 lbs. http://www.webbikeworld.com/r2/shoei/rj ... review.htm. The Shoei air has been my go to helmet as far as open face helmets go.
To make a long story short: I like the helmet, the weight, the price and the optics are very good. It doesn't appear to have the best ventilation, but where I live, it's usually windy, damp and foggy when the sun isn't shinning. That's the Coast for you, so I don't think ventilation is real high on my priority list. While Don pointed out that I have a narrow face the Shark Evoline Series 3 fits a slightly round face best. I think the fit is fine, and I can use the slightly extra space at times. The padding is completely and easily removable and feels good against my face. It actually feels narrower and you can see in the photo, it pretty snug. I'm sure after it been worn a few hundred miles, the padding will relax more.
That's it: I'm getting ready to put my Sena bluetooth system into it (plenty of ear pocket room) and will be ready to put it to the road test. But Webbikeworld.com says it's quiet. I'm sure it's going to be quieter than my RJ Air. The only thing I would caution against is dropping the helmet on its topside, as that is where the visor retractor is located,unike the smart Neotecs and others that have the retractor located on the side of the helmet where, I believe, it's better protected.
I hope you found this article and links useful.
Forgot to add: This helmet was pretty high on the list, but sadly did not make the cut - Just kidding....
Shark Evoline Series 3 Fusion Silver Photos
