2009-2011 kams kit
- Current bike(s): 2011 Vulcan voyager
2009-2011 kams kit
Has anyone installed the cams kit? is it difficult or should I pay the three hundred dollars for the install?
- hank43
- Been liked: 4 times
Re: 2009-2011 kams kit
Not difficult at all, if you can handle wrenches and read instructions. Let me ask you this,veeger1 wrote:Has anyone installed the cams kit? is it difficult or should I pay the three hundred dollars for the install?
1. what year is the bike
2. Is it still under warrantee (New or extended)
My bike is an '09 Voyager, I did the KAMS install myself, it is not that hard, but you will need torque wrenches (inch pound and possibly foot pound in capacity) and a decent set of socket, box, and end wrenches METRIC sizes of course, and a decent work area. One of the problems I had, was that my motorcycle garage is only a single car, and part of that room is taken up by a 2 cylinder air compressor, a bunch of welding gear, some hydraulic jacks, etc..
A part of the kit is a new radiator, new hoses, new fans, and other bits and pieces. You should not attempt this without the shop manual, as you will need to know how to remove the radiator (after draining it) and some other things the printed install instructions that come with the kit require, but don't really explain how to do. (Like something described as a "Cross over pipe" which is actually the mounting for the diode bridges for the charging circuit. Although there are pictures, they are not really that clear without looking at the the shop manual.
If you don't know how to drain the radiator without removing half the fairing and the gas tank, and other engine components, (I didn't) I would opt for the $300 dealer install.
And remember, if the bike is a 2012 or newer, it already has the KAMS on it.
hank
- debron
- Current bike(s): 2009 Voyager
I have to admit I'm not all that technically handy for larger projects, so I paid the dealer to do it. Worth every penny to me to have it done by someone else.
Joe Hellman
Central Point, OR
Central Point, OR
- debron
There are enough parts and pieces I think I would do the same!
- hank43
KAMS, OR KAWASAKI AIR Management System, is a system for the Voyager 1700 V-Twin consisting of a shroud and tight fitting gaskets for the radiator to engine interface, a new radiator, new hoses, and the all important REAR fan and engine shroud to direct the hot engine heat downward and away from the passenger. The new rear fan is switched on with the front fan, under control of the engine fan temperature sensor.bobber wrote:What does the KAMS kit do?
This does not make the engine run cooler, but does direct the heat away from the rider and passenger. I installed it on my 2009 Voyager when it first came out, along with wrapping the pipes, and replacing the radiator coolant with "Engine Ice". End result is that it does seem to make the bike a little cooler, especially in traffic. I think the KAMS was standard factory equipment from 2012 on.
- Current bike(s): 2011 Voyager
I'm picking up a 2011 tomorrow that the previous owner has the extended warranty. Does the extended warranty cover installation of the Kam system?hank43 wrote:Not difficult at all, if you can handle wrenches and read instructions. Let me ask you this,veeger1 wrote:Has anyone installed the cams kit? is it difficult or should I pay the three hundred dollars for the install?
hank
- Current bike(s): 2011 Blue/Silver Voyager
No the extended warranty does not cover it. I put some heat deflectors from RJOriginals on my 2011 Voyager and it made a difference to me.
Dave Smith
AMA, BK, CMA
AMA, BK, CMA
- Current bike(s): Vulcan Voyager
Vstar Silverado - Has liked: 0
I installed the jams kit on my 2011myself right after it became available. Took an afternoon and was money well spent.
