Radiator Fan doesn't run when bike is OFF.
NSASarge
Been liked: 6 times
Post by NSASarge »
Having owned a 2005 Nomad 1600, I am not used to the way the fan operates on my 2010 Voyager. On the Nomad, when the engine is hot and I stopped the bike and turned it completely off, the fan would run if it needed to. My Voyager fan will only run if I keep the ignition key turned to the RUN position after shutting the bike off. I know the coolant is not circulating and the fan on the Nomad was only running because the temp sensor told the fan to run, but, it also blew air at the front cylinder too. My bike does not have the KAMS. Has anyone re-wired the fan circuit to run if needed when the bike is switched off? Am I worried about a non-issue?
:tho:
Ride Safe
Shoot Straight
Speak the Truth
David & Deb
"NSASarge"
2010 Voyager
AVA: 6178
AMA/ROK: 3308207
AAA: 620111405125201
Patriot Guard Rider
Retired US Army MI
Retired Thomas Built Bus
Retired
Champion Trike
Been liked: 4 times
Re: Radiator Fan doesn't run when bike is OFF.
Post by hank43 »
NSASarge wrote:Having owned a 2005 Nomad 1600, I am not used to the way the fan operates on my 2010 Voyager. On the Nomad, when the engine is hot and I stopped the bike and turned it completely off, the fan would run if it needed to. My Voyager fan will only run if I keep the ignition key turned to the RUN position after shutting the bike off. I know the coolant is not circulating and the fan on the Nomad was only running because the temp sensor told the fan to run, but, it also blew air at the front cylinder too. My bike does not have the KAMS. Has anyone re-wired the fan circuit to run if needed when the bike is switched off? Am I worried about a non-issue?
:tho:
My '09 operates the same way, I think it's to conserve battricity.
1700Guy
1982 Honda 500 Silverwing
1981 Honda CB900C
Post by 1700Guy »
The way the bike is designed it is a non issue
