Fork seals
- Current bike(s): 1982 Suzuki GS1100GL
Fork seals
Does anyone have a recommendation for a fork seal/wiper? I'm about to rebuild the front end and this is a new bike to me.
Also, I see the manual calls for 20W/40 for the fork oil. Is that the general recommendation for fork oil?
- chevyman1
- Board Member
- Been liked: 16 times
Re: Fork seals
I rebuilt 4 sets of forks and used All Balls oil and dust seals in all of them and had no problem.
As for the oil I used 7w and 10w fork oil but I just changed out the oil in my forks and used
Dextron II Transmission fluid, it a 10w oil and a lot cheaper then fork oil.
- Bill O
2003 1200 Voyager
- Been liked: 6 times
Re: Fork seals
I picked me up a couple of these to try out. After reading the data and reviewed comments from others, I think this is a good tool. Those needing to fix leaking fork seals should give this a try.
http://sealmate.net/
Appropriate Disclaimer..... I am in no way associated with this company. (I'm just a consumer..)
Bill O
P.S. They're about $5 bucks each. Biggest problem......misplacing....
Bill O
1994 Voyager
2003 Voyager
2003 Voyager TriKing Trike
Nevada Patriot Guard Rider
1994 Voyager
2003 Voyager
Re: Fork seals
Hi Bill. let us know how you make out with these, sounds like it will work good if its just debris stuck in-between the seal and the tube. And the price is rightBill O wrote:I picked me up a couple of these to try out. After reading the data and reviewed comments from others, I think this is a good tool. Those needing to fix leaking fork seals should give this a try.
Bill O
- onegunguitar
Re: Fork seals
I had a fork seal leaking about 3 weeks ago. I seen this tool and decided to make one of my own to see if it was just dirt in there or if the seal went bad,which they are only 3 years old. Anyways,I took one of those round handi-wipe containers,cut it similar to the same shape as the seal mate tool,ran it between the fork and the seal itself and it hasn't leaked since.I did buy some neoprene fork protectors to put around them to keep the bugs and debris of the forks.
1999 Voyager XII
Re: Fork seals
Thanks for all the tips. :) So, 4 months later, the project is finally under way.
I'm confused. I have the fork nearly disassembled but I can't get the inner tube to come out of the outer tube. I have successfully removed the allen screw from the bottom of the fork and the dampener from the top. What is causing it to hang up still?
- jre258 in SoDak
Re: Fork seals
There is a snap ring under the black dust seal that needs to come out.
Re: Fork seals
I've got the snap ring and dust seal off too. Still no luck. It feels like something is hanging on the inner tube.
jre258 in SoDak wrote:There is a snap ring under the black dust seal that needs to come out.
- chevyman1
- Board Member
Re: Fork seals
The upper bushing is pressed in.
You have to keep extending the inner tube out agents them until they are tapped out, that will remove the seal and bushing.
Re: Fork seals
chevyman1 wrote:The upper bushing is pressed in.
Can you explain in more detail? Do I just pull the inner tube out repeatedly against the seals until it all pops it out?
- chevyman1
- Board Member
Re: Fork seals
Yes, that's what I do
Re: Fork seals
chevyman1 wrote:Yes, that's what I do
10-4! Thanks. I'll get a bit more rough with it tonight.
