2010 Voyager main fuse
Allen2
Current bike(s): Kaw 1700 Voyager
Kaw 1500 Venture
Kaw 500 Verture
Post by Allen2 »
Am new to this site and wish that I would have been on here sooner to learn about the wire rubbing and then shorting out under gas tank-- which blows the 30 amp main fuse. Think that is what happened to mine with 19100 miles on it. Battery is ok, the small amp fuses also ok, but nothing, everything dead. Where is the main fuse? Not able to find it, want to ck it out 1 st to make sure that it is blown and then will do the tape wrap thing on the wires running to the fuel pump. I know backwards, but didn't know about the problem before. Can anyone help me out?
1700Guy
1982 Honda 500 Silverwing
1981 Honda CB900C
Re: 2010 Voyager main fuse
Post by 1700Guy »
all fuses are under drivers seat in box ahead of battery
Allen2
Kaw 1500 Venture
Kaw 500 Verture
Post by Allen2 »
Thank you G.T. Have checked both fuse boxes there--- and did not see the main fuse,unless it is something that does not look like a fuse. Everything in those 2 boxes was all low amp stuff.
1700Guy
1981 Honda CB900C
Post by 1700Guy »
I am sorry I did not take you far enough it is under the seat but you need to take the cover over the battery off you will find it under there.
Allen2
Kaw 1500 Venture
Kaw 500 Verture
Post by Allen2 »
Thanks-- found it! it is to the right of the two small fuse boxes under the battery cover, on the starter relay cluster. You just pull straight up on it to get to the 30 amp fuse {there is a spare on the fuse holder case} yes, it was blown. So will be wrapping the wire that goes to the fuel pump.
