I have a 2011 Vulcan Voyager 1799 K-ACT ABS Ok so my Bridgestone OEM tires were done at 7K miles. So I was looking for a tire for the rear and I bought the Elite 3 Touring Bias-Ply Rear Tire160/80B-16 and the Michelin - Commander II Cruiser Front Tire130/90-16. I got it all back together and went for a ride and the ABS light stayed on the whole time. I then went to the shop manual and it said the light could come on for air pressure issues and tires that are not recommended for this bike.
I did a fault code check and it just keep giving me 12 which is not code but I can not get the light to shut off or determine what the issue is.
It all started after I changed the tires. The front is the exact size as the OEM the rear tire is not. So any suggestion?
Thanks Eric
ABS light stays on Vulcan Voyager 1700 2011
- Terros
- Current bike(s): 2004 VTX1300R
Re: ABS light stays on Vulcan Voyager 1700 2011
ok, I'm no expert, but let's check stupid stuff. Have you checked all wire connections from one end to other? Is there a fuse that if blown can cause this condition? Have you tried disconnecting the battery and reconnecting in an effort to reset?
I find it hard to believe the system would not except a tire of a different size. There must be some margin of error because the same size tire from another company is probably not the same physical size.
That's all I got,
Bob
That's all I got,
Bob
Live dying or Die living
- Me Again
- Been liked: 262 times
had a similar problem on my van.
turned out when I changed brakes I twisted the wire for the sensor.
had to replace the sensor.
- David (N. Alabama)
Front wheel is on backwards so the sensor is not reading the pickups.
