For some strange reason on my 2002 voyager I lost my clutch and when I got home I opened up the rez. and saw the fluid was low is the reason. My question is I have refilled it so do I bleed the clutch by bleeding it through the front and back brake. I looked all over to find a bleed sight for the clutch and couldn't find it. Could you please tell me how to bleed the clutch.
Thx
Clutch
- Current bike(s): 2002 Kawasaki voyager
- Has liked: 114 times
- Been liked: 289 times
Re: Clutch
https://skydrive.live.com/?cid=25f882b6 ... CA8D%21173" onclick="window.open(this.href);return false;
use this link kindly provided by Mr. Jensee for a wealth of info. You'll want to go to Chapter 5 of the Service Manual where it will provide all the info you require to bleed the clutch.
- debron
Re: Clutch
Or here, in the AVA Tech section:
http://www.amervoyassoc.org/zg1200manuals.php
See page 5-6. It's pretty easy to get to and do.
Re: Clutch
I recommend replacing the bleeders on the brakes and the clutch with speed bleeders. These along with a silicone tubing will make bleeding them uncomplicated.
http://www.speedbleeder.com" onclick="window.open(this.href);return false;. Sizes for brakes is SB7100S and clutch is SB8125.
