Instrument Panel Issue
ThumperHitch
Current bike(s): 2015 Kawasaki Voyager 1700
2009 Kawasaki KLR685 (650)
Post by ThumperHitch »
Periodically, the instrument panel freaks out. The gear indicators ALL flash, the RPM's drop to zero and the temp gauge pegs at H. This is on a 2015. Runs fine while this occurs, doesn't miss a beat. My local dealer and Kawasaki have been working on the issue. They have already replaced the wire harness and are set to replace some other components.
Just wondering if anyone else has experienced this.
boscoe
Current bike(s): 2011 Voyager
Re: Instrument Panel Issue
Post by boscoe »
Check your grounds, test the battery. Often a weak battery can cause instrument panel to freak out.
2011 Voyager 1700
Ebony/Pearl Meteor Gray
Bridgestone Exedra Max tires in stock sizes
Kuryakyn Longhorn Offset Dually Highway Pegs
DEI Titanium exhaust header wrap
Polk Audio db521 speakers
Mobil 1 10W-40
