Shinko Tires?
Own something other than a Voyager? This forum allows you to more easily find non-Voyager articles.
Jim&Debbie
Current bike(s): 1987 Voyager
1992 Voyager
Shinko Tires?
Post by Jim&Debbie »
Has anyone have any experience with these tires? I am looking at the 230 Tour Master tires, I wrote the company for specs, and they are rated for heavy loads and speeds.
Any experience with the brand would be helpful. Thanks
87 Voyager XII (being resurrected)
92 Voyager XII (standing by)
Rhinestone Kawboy
1970 Honda CL350 Scrambler
1977 Carabela Marquesa 125 MX
Re: Shinko Tires?
Post by Rhinestone Kawboy »
Do a search on Shinko on this board, and you will get several listings on the subject.
Iron Butt Member #47339
Furchin
Re: Shinko Tires?
Post by Furchin »
Just mounted up the rear shinko 230 tour master last week on one of my voyagers. Too early to tell about results but a lot of my Eliminator buddies are running them and really like 'em. Only bad thing I have read and experienced myself is balancing them. Mine took 3.5 ounces of weight. But hey, it rides nice now. Now for getting to mounting the other one that I bought for the rear of one of my Eliminators.
'96 Kawasaki Voyager
Jim&Debbie
1992 Voyager
Re: Shinko Tires?
Well I have had my Shinko's mounted for about 500 miles now, and I must say I have no complaints.
Very quiet, smooth and they grip very well.
90% of my riding is 2 up.
We'll see how many miles they can rack up this summer :thmup:
tregal16
Re: Shinko Tires?
Post by tregal16 »
Furchin, you mention the weight for balancing the tires... have you or anyone ever tried those bead things you put inside the tire to balance it? Does it work? it doesn't seem all that expensive around $20 per tire if it works.
If it is worth having, it is worth taking care of...
Furchin
Re: Shinko Tires?
Post by Furchin »
tregal16 wrote:Furchin, you mention the weight for balancing the tires... have you or anyone ever tried those bead things you put inside the tire to balance it? Does it work? it doesn't seem all that expensive around $20 per tire if it works.
I myself have not used the beads. Have heard pro & con concerning their useage. some good, some bad.
On a side note, do you ever get to central Pa?
David (N. Alabama)
2014 Triumph Trophy SE
Re: Shinko Tires?
Post by David (N. Alabama) »
I just ordered a set of Shinko tires for my KLR 650. Under $100 for a pair.
I would look at Ride-on instead of the beads since it also helps prevent flat tires.
Has liked: 95 times
Been liked: 155 times
Re: Shinko Tires?
Raven has a site with Ride-On listed for sale.
http://www.barebonesmctours.com/apps/webstore/
I'm not advertising for him, just sharing information as I'm sure it can be gotten elsewhere. Just plugging a site as a friend! :wnk2:
tregal16
Re: Shinko Tires?
Post by tregal16 »
I just read about the beads...wondered if anyone tried them. I will check out the ride on product also.
Depends on where in central PA. I am in south western PA, but have family in south central PA (Harrisburg area). I have been known to jump on the bike on a Sunday and do a few hour ...Let me know where you are, maybe we could meet up some Sunday.
Furchin
Re: Shinko Tires?
Post by Furchin »
Tregal, My location is listed in my profile. Guess it was hidden too much. :hmm: Huntingdon County just off route 22
Mythic State Rider
Re: Shinko Tires?
Post by Mythic State Rider »
Jim&Debbie wrote:Well I have had my Shinko's mounted for about 500 miles now, and I must say I have no complaints.
So, how many miles did you get out of them? My new to me 1998 Voyager XII has a fresh set of the Tour Masters.
chris.trombley
Current bike(s): 1993 kawasaki zg1200/b7 voyager
Re: Shinko Tires?
Post by chris.trombley »
I have just over 6,000 miles on the set that was on the bike when i got and the guy I bought it from said they were brand new maybe a couple thousand more if I'm lucky 93 XII :hmm:
Live life to the fullest and have fun you only get one chance
Chris north Ga
93 xll[ totaled]
99 Suzuki Intruder 1500 lc
stubabe
2003 Kawasaki Concours (Motorcycle Heaven)
Re: Shinko Tires?
Post by stubabe »
After reading all the posts on Shinko tires I thought I would chime in. I purchased a set of Shinko 777's for my 2003 Voyager back in July. I replaced the back tire first and a week later replaced the front tire. I had Ride-On balancer/sealant put in both tires and with just a new rear tire everything was fine. I put the new front tire on there and at 65 mph the front tire bounced like a basket ball. I called up Bike Bandit and told them what was going on and they said it was a balance problem. I put more Ride-On in the tire bringing it up to the max recommended and it settled down a little but was bouncing all over at 75 mph. I pulled the tire off and took it back to have it balanced the conventional way. It required 2 ounces of weights to get it balanced but now is smooth as glass. Had I read the posts before I bought these tires I would have coughed up a few extra bucks and bought the Dunlop E3's. They will be my next tire purchase.
Carrier take-offs and landings... The best 2-second rides of your life!
Return to “All Other Brands General Forum”
