Breakthrough! Keep Your Legs From Getting Burnt From Engine
flip18436572
Re: Breakthrough! Keep Your Legs From Getting Burnt From Engine
Post by flip18436572 »
I don't ride in shorts, but I do like the thought process. Because most people think things can only be done one way. This may bring other people to do other things that might make things better for us.
David (N. Alabama)
2014 Triumph Trophy SE
Post by David (N. Alabama) »
My bike came with a rubber gasket where you put the pipe insulation. Did your bike not have that?
flip18436572
Can you show me a picture of the rubbers on the lowers that is supposed to be there from stock. Mine does not have anything else either.
Chris near Kansas City
Philip, I can't remember if they were on your bike or not. Easy to put on though if they aren't. Here's a picture though. About an inch or two in from the back edge.
Steve in Sunny Fla
Post by Steve in Sunny Fla »
chris - your pic is also missing the factory gasket piece. it actually rests up against the cylinder block and stops the air from hitting your legs. Steve
oops looked again. maybe it's there - the black i was seeing seemed to be behind the place it's supposed to be.
Jim&Debbie
Current bike(s): 1987 Voyager
1992 Voyager
Post by Jim&Debbie »
I have been thinking how to divert the heat from slipping through that area too. (the desert heat it enough, I dont need the engine heat too) My bike does have the factory rubber seal, but it does not close the gap completely, I had thought of putting plexi glass cut to the motors contours with some soft foam edging to press against it.
87 Voyager XII (being resurrected)
92 Voyager XII (standing by)
Toddo
Current bike(s): '01 Voyager Xll
Has liked: 2 times
Post by Toddo »
I took the bottom fairings off because of the excessive heat when summer riding in shorts. I was very surprised how much heat comes off the engine. And I have the full rubber gasket from top to bottom. I was under the impression that there was no breeze to dissipate the heat that was present. Without the bottom fairings is a little better but still not good.
Take care,
Toddo
Sunsets never hurt your eyes.
'02 Voyager
MTN99
Post by MTN99 »
Toddo,
If you want to get more air in the cockpit get some Baker airwings or the OEM Kaw ones. (If you can find'em) They work great, had'em on our 91 and will be soon putting a set on our 99... They can be set to bring in more air or can be set to block cooler air in the winter months
I'm not afilliated with Baker airwings but can attest that they do work... :thmup:
Hope this helps.
Now Retired
Tony & Gail
Grass Valley Ca.
