Saddle Bag Reflectors 02 XII
Been liked: 106 times
Looking to modify my rear saddle bag reflectors to running lights using LED's. Anyone done this? What LED lamp would fit in this tight lens. Any suggestions would be greatly appreciated.
David (N. Alabama)
2014 Triumph Trophy SE
Re: Saddle Bag Reflectors 02 XII
Post by David (N. Alabama) »
Did you search the tech tips area of the website? I know several people have made this mod. If you don't find it there, I'm sure someone will post up a procedure before too long.
Thanks, Yes I did and the only thing I can find on this and other forums is the rear trunk and rear fender light conversion. I have allready done these and doing this mod would make it look like one solid light accross the saddle bags and fender like the trunk. It would also look stock.
David (N. Alabama)
I believe Chris from Kansas city has this mod on his '01. You might want to send him a PM.
Chris near Kansas City
He has them, but he didn't put them in. Mike Soden installed them when he owned the bike. Some pictures here: http://geehom6969.easycgi.com/usefulinf ... %20mod.pdf
Basically, you just open a hole, glue or epoxy some sort of holder in place and then stick a rubbery light bulb socket in the hole.
doug of so fla
Current bike(s): 07 gold wing
Post by doug of so fla »
Another good rear signal light mod is the one from Sierra Elec, They have a inexpensive simple kit that you drill a hole in your rear turn signal hsg and install a red led and duriing the day it is not seen but at night it leaves the turn signal red and your amber bulb overrides it when signaling about $15.00, I think. it would further enhance the reflector mod. :hmm:
Doug, that is how mine works, though it's not LED. I should try taking a picture some night of the back end of the '01. Mike did a fine job of setting everything up.
Thanks Chris for the pictures. We talked about this briefly sitting on the curb at the AVA rally. This gives me some Idea's for my winter project Voyager mod.
Also thanks Doug and Chris for the turn signal mod. I think I will do this also.
Doug,
Could your please provide the link. I can't find it.
Wylee
Current bike(s): 2000 Voyager xii
1989 Yamaha Virago
Post by Wylee »
Kim, I got mine from (http://www.electricalconnection.com/oth ... sk-int.htm), they work great lights my rear up at night but you don’t notice them in daylight. easy to install. You are close to me; if we can meet up I will show you.
Wylee
:clap:
doug of so fla
Kim / Wylee showed the correct ones, I got them from Serria but they were Elec Connection pn#, I have been off the computer for awhile , thanks . Wylee :clap:
I will order it. Wyle, I am going out of town for a week but will PM you when I get back. Would like to check yours out.
