Steve
They are talking about Rotella synthetic and not Mobil one. I think you may know that.Aufgeblassen wrote:That's weird! All the Wal Marts I have been in (in FL & Georgia) have had several weights of Mobil 1 in quarts, gallons, and even 5 quart bottles.flip18436572 wrote:I have checked multiple walmarts in our area and none have had the synthetic. I don't go to walmart very often, so I may only be there when it is all gone.
AUFGEBLASSEN -Aufgeblassen wrote:That's weird! All the Wal Marts I have been in (in FL & Georgia) have had several weights of Mobil 1 in quarts, gallons, and even 5 quart bottles.flip18436572 wrote:I have checked multiple walmarts in our area and none have had the synthetic. I don't go to walmart very often, so I may only be there when it is all gone.
Really? Do you have oil tests for your motorcycle oil running one then the other under the exact same conditions for the exact same miles? Since you say that oil tests are a waste of time, I really doubt you have any data to back anything up.Aufgeblassen wrote:The bottom line (drum roll, please): Mobil 1 is much higher quality than Rotella Synthetic. STORY HAS ENDED.
and if you fail to maintain your "perfectly" running engine, it will fail sooner then later. Hopefully that failure will happen when you first start it up and not as you are cruising down the road...what is that saying....pay me now...or PAY me later!Aufgeblassen wrote:
If your engine is running perfectly fine, just keep running it. A good analogy, would be to just keep using a light bulb, until it burns out, rather than changing it before it burns out. It could burn out in 1 hour, or thousands of hours.
