Finally got some warm weather and of course Murphy arrived in time for a ride . . . . . got her warmed up and when I let out the clutch, she immediately dies. Is the kick stand interlock the likely culprit? Any thoughts on what to investigate first? Hate to have 70F + clear blue skies and a bike that won't go anywhere . . . .
Andy
Stalls when letting out the clutch
- debron
Re: Stalls when letting out the clutch
Does it die if the tranny is in neutral and you let out the clutch? If it does it only when in gear, than the culprit could be the kick stand switch. I' not sure how to bypass the switch to test it. When the kick stand is up, there should be continuity through the switch (BK/R and BK/Y).
- Nathan (South Carolina)
The trunk light switch is the same as the kick stand switch. Swap them out and see if that helps.
Lone Eagle
2001 Kawasaki Voyager XII
Sure sounds like the kickstand interlock to me!
Yup . . . .swapped the trunk switch out and it worked
Went to the dealer and ordered a new switch . . . . . would have used Carl but driving to the dealer gave me an excuse to put on 75 miles taking the scenic way
75F . . . . . what a beautiful day to ride!
Thanks again . . . . .
'02 Voyager XII
Seneca, SC
'02 Voyager XII
Seneca, SC
