When you live alone and the neighbors aren't around sometimes you have to use a little ingenuity to solve some problems. Welded up a quick spring compressor that goes around my vise. Worked great and only took about an hour to draw it up and fabricate. Just thought I would share the idea.
"The Constitution was written so that the People could control their government NOT so the government could control it's people"........LT.Col Allen West
.... Good idea !!! It took me a few minutes to see that the two lower tabs of your tool, hook under the vice jaws,,,, Looks like it should compress the fork spring quite well ! tony
Lacking welding skills, and equipment, I used a Gear Puller to push the top caps down into the fork tubes, so I could put the C-clips in place -- I gripped it on the triple-tree. It may be overkill, but it worked, in the end. Cheers!
