When you live alone and the neighbors aren't around sometimes you have to use a little ingenuity to solve some problems. Welded up a quick spring compressor that goes around my vise. Worked great and only took about an hour to draw it up and fabricate. Just thought I would share the idea.
Fork Spring Compressor
- Vtwinguy
- Current bike(s): 1997 Kawasaki Voyager
"The Constitution was written so that the People could control their government NOT so the government could control it's people"........LT.Col Allen West
- Lucasind
- Has liked: 194 times
- Been liked: 69 times
Re: Fork Spring Compressor
.... Good idea !!! It took me a few minutes to see that the two lower tabs of your tool, hook under the vice jaws,,,, Looks like it should compress the fork spring quite well ! tony
- Been liked: 238 times
Lacking welding skills, and equipment, I used a Gear Puller to push the top caps down into the fork tubes, so I could put the C-clips in place -- I gripped it on the triple-tree. It may be overkill, but it worked, in the end. Cheers!
