How do i remove my swing arm
- Current bike(s): 1986 Voyager 1300 and my amazing 1975 Honda GL 1000 built not bought
My Ujoint went out and I need to replace it but cant seem to figure out how to remove the swing arm. How do you get the pivot bar away from the frame so I can slip the swing arm out?
- Bill O
2003 1200 Voyager
- Been liked: 6 times
Re: How do i remove my swing arm
Zack,
If it's like the 1200, after you remove the adjusting nuts from the swing arm frame, the pins that hold the swing arm to the frame need to be removed. most have a threaded center where you can screw in a bolt secured in a slide hammer to pull the pins out.
I hope I haven confused you.
Bill O
Bill O
1994 Voyager
2003 Voyager
2003 Voyager TriKing Trike
Nevada Patriot Guard Rider
1994 Voyager
2003 Voyager
