How do i remove my swing arm
zach861300
Current bike(s): 1986 Voyager 1300 and my amazing 1975 Honda GL 1000 built not bought
Post by zach861300 »
My Ujoint went out and I need to replace it but cant seem to figure out how to remove the swing arm. How do you get the pivot bar away from the frame so I can slip the swing arm out?
Bill O
2003 1200 Voyager
Been liked: 6 times
Re: How do i remove my swing arm
Post by Bill O »
Zack,
If it's like the 1200, after you remove the adjusting nuts from the swing arm frame, the pins that hold the swing arm to the frame need to be removed. most have a threaded center where you can screw in a bolt secured in a slide hammer to pull the pins out.
I hope I haven confused you.
Bill O
1994 Voyager
2003 Voyager
2003 Voyager TriKing Trike
Nevada Patriot Guard Rider
zach861300
Thanks thanks!!! Got it
