I know I ask al ot of questions... Here's another - 1st gear
- HawkeSHR
- Current bike(s): 2008 Kawasaki KLR 650
1993 Kawasaki ZG1200 - Location: Perkasie, PA
When the bike is started (full choke to start then I give it time to warm up). I can go from first into neutral but if I go from first into second, it will not ratched up into second until after it warms up (about 5 minutes of riding).
I checked the clutch reservior and fluid is full, fluid looks clean. Clutch lever does not bind and shifter lever works fine.
The hydrolic clutch thing is new to me...
Any troubleshooting steps are appreciated.
Thanks again!
Steve
Thanks again!
Steve
- vxiirider
- Has liked: 96 times
- Been liked: 32 times
Re: I know I ask al ot of questions... Here's another - 1st
Shift at or just above 3000 RPM and it should go into second easily.
John Ramsay
Charlotte, Michigan
'02 GL 1800 Goldwing Trike
Charlotte, Michigan
- HawkeSHR
\\vxiirider wrote:Shift at or just above 3000 RPM and it should go into second easily.
Thanks for the feedback!
The Voyager XII is designed that way to avoid shifting before the engine is warmed up. This is the positive neutral finder everyone talks about. Rev to 3000 rpm until the engine is circulating oil and it will shift normally.
- HawkeSHR
I did get that thought about the warmup, I just need a bit more patience...Mr Jensee wrote:The Voyager XII is designed that way to avoid shifting before the engine is warmed up. This is the positive neutral finder everyone talks about. Rev to 3000 rpm until the engine is circulating oil and it will shift normally.
When I'm new to a bike, every little idosyncrasy comes into mind as if something is wrong.
..and the online documentation is appreciated (your signature link)!
Thanks again!
Steve
- Lance McCaw
My 87 does that also. When on the center stand running it in the winter I have to go to 1st then it will go to 2nd right away. I start it every 2 weeks and run it till the fan kick on, While in gear.
- Current bike(s): 2003 1200
Not necessary to start it in the winter. Add some Seafoam to the gas, then park it till spring.
- debron
If you do this, you will definitely also want a "battery tender" of some sort. . . .voyager55 wrote:Not necessary to start it in the winter. Add some Seafoam to the gas, then park it till spring.
- Lance McCaw
I keep my garage at 50 degrees all winter long ! But I also keep a tender on it also !
- HawkeSHR
I ride a little in the winter months (weather permittingdebron wrote:If you do this, you will definitely also want a "battery tender" of some sort. . . .voyager55 wrote:Not necessary to start it in the winter. Add some Seafoam to the gas, then park it till spring.
- kjsett
Where do you get a long enough extension Cord????HawkeSHR wrote:I ride a little in the winter months (weather permittingdebron wrote:If you do this, you will definitely also want a "battery tender" of some sort. . . .voyager55 wrote:Not necessary to start it in the winter. Add some Seafoam to the gas, then park it till spring.), but it is always on the tender.
Couldn't help myself.
No, the devil didn't make me do it, I did it all my self..
Myself, rarely leave the bike alone long enough to need the tender, but I use one when I need to (but not while riding).
