I know I ask al ot of questions... Here's another - 1st gear
HawkeSHR
1993 Kawasaki ZG1200
Post by HawkeSHR »
When the bike is started (full choke to start then I give it time to warm up). I can go from first into neutral but if I go from first into second, it will not ratched up into second until after it warms up (about 5 minutes of riding).
I checked the clutch reservior and fluid is full, fluid looks clean. Clutch lever does not bind and shifter lever works fine.
The hydrolic clutch thing is new to me...
Any troubleshooting steps are appreciated.
Thanks again!
Steve
vxiirider
Tourer
Tourer
Has liked: 96 times
Been liked: 32 times
Re: I know I ask al ot of questions... Here's another - 1st
Post by vxiirider »
Shift at or just above 3000 RPM and it should go into second easily.
John Ramsay
Charlotte, Michigan
'02 GL 1800 Goldwing Trike
HawkeSHR
Post by HawkeSHR »
vxiirider wrote:Shift at or just above 3000 RPM and it should go into second easily.
Thanks for the feedback!
The Voyager XII is designed that way to avoid shifting before the engine is warmed up. This is the positive neutral finder everyone talks about. Rev to 3000 rpm until the engine is circulating oil and it will shift normally.
HawkeSHR
Post by HawkeSHR »
Mr Jensee wrote:The Voyager XII is designed that way to avoid shifting before the engine is warmed up. This is the positive neutral finder everyone talks about. Rev to 3000 rpm until the engine is circulating oil and it will shift normally.
I did get that thought about the warmup, I just need a bit more patience... :roll: ;-) :-D
When I'm new to a bike, every little idosyncrasy comes into mind as if something is wrong.
..and the online documentation is appreciated (your signature link)!
Thanks again!
Steve
Lance McCaw
Post by Lance McCaw »
My 87 does that also. When on the center stand running it in the winter I have to go to 1st then it will go to 2nd right away. I start it every 2 weeks and run it till the fan kick on, While in gear.
voyager55
Current bike(s): 2003 1200
Post by voyager55 »
Not necessary to start it in the winter. Add some Seafoam to the gas, then park it till spring.
debron
Post by debron »
voyager55 wrote:Not necessary to start it in the winter. Add some Seafoam to the gas, then park it till spring.
If you do this, you will definitely also want a "battery tender" of some sort. . . .
Lance McCaw
I keep my garage at 50 degrees all winter long ! But I also keep a tender on it also !
HawkeSHR
Post by HawkeSHR »
I ride a little in the winter months (weather permitting :windy: ), but it is always on the tender.
kjsett
2009 Suzuki Vstrom DL650
Post by kjsett »
Where do you get a long enough extension Cord???? :devl
Couldn't help myself. :Cball
No, the devil didn't make me do it, I did it all my self.. :hpdc:
:wnk2:
Myself, rarely leave the bike alone long enough to need the tender, but I use one when I need to (but not while riding). :bat:
