Progressive site says 11-1102 for 86. 11-1122 for 93... does anyone know if there is a big difference that could cause a problem with me using them in my '93 from an '86?
Thanks in advance!
Progressive Form springs from and 86 into a 93?
- HawkeSHR
- Current bike(s): 2008 Kawasaki KLR 650
1993 Kawasaki ZG1200 - Location: Perkasie, PA
- Been liked: 272 times
Re: Progressive Form springs from and 86 into a 93?
I know there is a difference in the tube diameter so they probably will not fit.
An Alternative may be to swap forks Don't quote me on this without further info.
- doug of so fla
The diameter is different so I don't think you could swap forks & being they have a different pn# they probably won't be the same, A call to either Carl or Progressive should get you the proper info you need.
- Guru
76 kz900 LTD
the difference is the internal diameter of the tubes, OD is the same but the 86s had thinner tubing which caused flex. the progressive springs for the 86 are too thick to fit the 87-03 tubes........
- chevyman1
- Been liked: 16 times
I have a set of 1991 fork tubes with progressive springs in them ready to go.
PM me if you are interested.
- HawkeSHR
Thanks Carl and each of you for chiming in. Much appreciated! I do not want to do anything to mess up this motorcycle...carl leo wrote:the difference is the internal diameter of the tubes, OD is the same but the 86s had thinner tubing which caused flex. the progressive springs for the 86 are too thick to fit the 87-03 tubes........
