Progressive Form springs from and 86 into a 93?
HawkeSHR
1993 Kawasaki ZG1200
Post by HawkeSHR »
Progressive site says 11-1102 for 86. 11-1122 for 93... does anyone know if there is a big difference that could cause a problem with me using them in my '93 from an '86?
Thanks in advance!
Me Again
Been liked: 262 times
Re: Progressive Form springs from and 86 into a 93?
Post by Me Again »
I know there is a difference in the tube diameter so they probably will not fit.
An Alternative may be to swap forks Don't quote me on this without further info.
doug of so fla
Current bike(s): 07 gold wing
Post by doug of so fla »
The diameter is different so I don't think you could swap forks & being they have a different pn# they probably won't be the same, A call to either Carl or Progressive should get you the proper info you need.
carl leo
Guru
Guru
76 kz900 LTD
60 NSU supermax
Post by carl leo »
the difference is the internal diameter of the tubes, OD is the same but the 86s had thinner tubing which caused flex. the progressive springs for the 86 are too thick to fit the 87-03 tubes........
I have a set of 1991 fork tubes with progressive springs in them ready to go.
PM me if you are interested.
:thmup:
HawkeSHR
Post by HawkeSHR »
carl leo wrote:the difference is the internal diameter of the tubes, OD is the same but the 86s had thinner tubing which caused flex. the progressive springs for the 86 are too thick to fit the 87-03 tubes........
Thanks Carl and each of you for chiming in. Much appreciated! I do not want to do anything to mess up this motorcycle...
