Easy way to get at Rear Brake Light Switch?
ghostler
Has liked: 3 times
Been liked: 10 times
Post by ghostler »
Trying to find an answer in the forums, must say the search engine is not cooperating. I used the search terms, "rear brake switch problem", and it rejected rear, brake and switch saying words are too common.
I've got a bad rear brake switch. There's 2, one off the rear pedal and one in an extremely hard to get to place. The problem is with the hard to get to one. This is the pull switch mounted off a bracket on the master cylinder with a long wire spring to the foot operated cam. Seems to get it off I must disconnect hydraulic line parts like the banjo bolt because the black aluminum mounting bracket is in the way. Otherwise access is impossible.
1. Is there an easy way to gain access and replace the rear brake light switch without dismantling the hydraulic system?
2. Has anyone replaced this switch with a banjo bolt pressure switch? These pull switches seem to be problematic.My brake light is stuck on, I jiggled it with a set of dykes, but fix was only temporary. It is a bugger to get to. About only drawback with the banjo switch might be lack of space above the banjo bolt limiting choices on banjo switches.
(I replaced the cheap Suzuki Savage light duty front hand lever switch with a banjo switch and that got rid of that weak link. The back is a manual link so had to replace the back pull switch with a like one.)
3. What thread is the rear master brake cylinder banjo bolt? Is it a 1mm or 1.25mm thread pitch?
If I have to dismantle the hydraulics for access so be it. I've never seen such a design before reminiscent of our modern cars. (Had to pull the steering wheel and remove the entire dash board to replace the water heater core for interior heat on my 1999 Chevrolet S10 pickup.)
George Hostler
Clovis, NM, US
http://tsammcentral.org/
1971 Honda CB100
Has liked: 119 times
Re: Easy way to get at Rear Brake Light Switch?
The switch behind the black plastic cover is for the cruise control cancel on "87 and later zg1200 voyagers. The switch behind the black aluminium casting is the brake light switch. One thing to remember is that it works opposite of a lot of spring operated switches in that it turns on the light later when the black plastic switch body is raised in the black plastic nut, and on earlier when the switch body is lowered in the black plastic nut.
1) if there is an easier way I haven't found it;
2) I haven't done this but perhaps others have;
3) 1.25mm
http://www.kawasaki-techinfo.net/showOM ... ng_code=EN" onclick="window.open(this.href);return false;
Page 121 shows the adjustment procedure. One note for this manual download: wrong rear wheel size in specifications, lists 16" but is actually 15".
I adjusted mine to turn on using a multimeter when I had the casting off and the brake pedal was depressed the specified amount. Easier then than after the casting is in place. Or one could use 2 wire leads going to the switch from a 12V battery. One lead would have a bulb inline. When the switch is adjusted to where it should be, the bulb will go on.
carl leo
Guru
Guru
76 kz900 LTD
60 NSU supermax
Post by carl leo »
a simple way to adjust the switch is to unplug it from the harness next to the fuelpump, then just rotate the switch body up or down to make the switch make contact, easily checked by just plugging it up and trying the lever........carl
:hpdc:
ghostler
Has liked: 3 times
Post by ghostler »
Thanks for the adjustment tip, Leo. My switch is 14 years old and it looks like the original lubrication has dried up in it. Although I could probably clean, I'm thinking replacement is in order.
Thanks Dave for the info on accessibility and banjo bolt thread pitch. Regarding your comment,
triton28 wrote:One thing to remember is that it works opposite of a lot of spring operated switches in that it turns on the light later when the black plastic switch body is raised in the black plastic nut, and on earlier when the switch body is lowered in the black plastic nut.
For my 2001, switch is normal open when the black plastic piston is retracted into the switch housing, and switch is closed when extended? (Extends when brake is applied.)
George Hostler
Clovis, NM, US
1971 Honda CB100
Ozymandias
Current bike(s): 2010 Kawasaki 1700 Voyager
Post by Ozymandias »
ghostler wrote:Trying to find an answer in the forums, must say the search engine is not cooperating. I used the search terms, "rear brake switch problem", and it rejected rear, brake and switch saying words are too common.
The forum search facility is not the world's best. I recommend that you use the Google "Search this site" technique.
Search example:
(in google search box)
hammer site:homedepot.com
I have used it here in the past and it is much better than the one provided by the forum software.
Hope this helps you and anyone else who has had a similar problem.
1975 Goldwing (found a good home for it)
2003 Nomad 1500 (traded for the Voyager)
ghostler
Has liked: 3 times
Post by ghostler »
Thanks, Ozymandias for the search tip. I'll give it a shot next time.
So far, it looks like replacing the banjo bolt on the rear brake master cylinder side won't work. There is insufficient clearance. I could go to the rear slave cylinder banjo bolt and extend wires to that location, wire tie them to the brake line or use a piece of combing or electrical tape. This is an option.
The other solution is simply replace the switch with a new OEM one. Ron Ayers has it for $15. Lo and behold, as stated, the switch does retract instead of extend when the brake pedal is pushed. Regarding my question as to orientation, that I can figure out by simply shorting the wires above the switch with the ignition switch on. I imagine that the switch is off until activated by depressing the brake lever.
Regarding accessing the factory switch, it looks like I just simply remove the 2 master cylinder aluminium mounting plate bolts, then back out the 2 Allen head bolts holding the master cylinder, then I can access the switch assembly and swap it out. I might still go the banjo bolt switch route, seems to be less problematic.
In a related story, I finally purged the old brake fluid and put in new. It took 3 full reservoir amounts for each to purge all 3 slave cylinders front and back. Fluid was the color of coffee. I don't think the fluid was ever changed since bike was manufactured in late 2000. I might replace the rubber brake lines with braided stainless steel ones, although they still appear to be in good condition.
Has anyone had an OEM brake line rupture on them? Do they go bad with age?
George Hostler
Clovis, NM, US
1971 Honda CB100
Ghostler;
when the switch pull (contact surface) spindle, which has the hole near the end for the spring, is not connected to the brake shaft by the spring, as in "sitting on your workbench", the circuit is closed and the brake light would be illuminated.
While mounted in place, the spring is used to hold the contact surface of the pull spindle away from the switch body internal contacts so the body of the switch must be adjusted, as Carl suggested while the black plastic nut is held from turning, away from, or perhaps, toward the contact surface of the pull spindle, to a point where 15mm of the lever foot pad travel (5/8") causes the contact surface of the pull spindle to make contact with the switch body contacts and close the circuit, thereby illuminating the brake light.
If the switch body is too high in the nut the brake light may not come on, and if the switch body is too low in the nut the brake light will always be on. I start with the body high in the nut, (open circuit) and work down into the nut until the circuit closes with the specified lever foot pad travel.
Sorry if this sounds confusing, but it was confusing to me before I got used to it.
ghostler
Has liked: 3 times
Post by ghostler »
Thanks Dave. Problem I got with the switch is that it binds sometimes when spring pulls on it when releasing the pedal, leaving brake lights on when it should turn off. Otherwise, depressing the pedal 5/8" activates lights. Short term fix is to clean up the switch so it moves more freely. Long term fix is simply replace it with new.
George Hostler
Clovis, NM, US
1971 Honda CB100
ghostler
Has liked: 3 times
Post by ghostler »
Speaking of oddities on this bike, I was wondering why there is an odd chatter buzzing when applying the front brakes. The dowels that align and slide one brake pad are lubricated. I just now replaced the OEM brake pads with aftermarket ones of modern materials that tend to tear up the rotors less. OEM were down to 3mm, so they still had some life in them.
I also just placed along with the rear brake light switch an order for all seals, boots and springs for both front calipers. When I get a chance, will overhaul the front calipers, may also order new brake lines although the old still look good with stainless steel ones. I'm a little reticent over 15 year old rubber.
George Hostler
Clovis, NM, US
1971 Honda CB100
when you overhaul the front calipers, a dental hygienist's tool with a bend of the tip works great to remove any corrosion in the squared recesses, in the body of the caliper, for the the squared caliper seals.
This corrosion removal, if needed, lets the new seals seat properly and the piston fits in so easily when cleaned and reinstalled.
ghostler
Has liked: 3 times
Post by ghostler »
triton28 wrote:when you overhaul the front calipers, a dental hygienist's tool with a bend of the tip works great to remove any corrosion in the squared recesses, in the body of the caliper, for the the squared caliper seals. This corrosion removal, if needed, lets the new seals seat properly and the piston fits in so easily when cleaned and reinstalled. Dave
Thanks for the tip, Dave. I've also found that since I don't have such dental tool, using a small Allen wrench or flat tip of an off-set screwdriver works, too.
Amazon.com has http://www.amazon.com/dp/B00OBPJEUC/
Kawasaki 1987-1993 ZG1200 Voyager XII Galfer Braided Stainless Steel Front Brake Line Kit
Will this fit the 2001?
George Hostler
Clovis, NM, US
1971 Honda CB100
ghostler
Has liked: 3 times
Post by ghostler »
Other line kit suppliers state years 1987 - 2003 for their kits. At $89, this kit was half the price of theirs. Even though states for 1987 - 1993, I could not see any logical reason for it not fitting my 2001. I like the idea of eliminating the splitter and driving both calipers directly from the master cylinder, certainly simplifies things.
I clicked "Order", it's a done deal, will report its fit when I install it. :hpdc:
George Hostler
Clovis, NM, US
1971 Honda CB100
roadkingrich
Current bike(s): 99 Voyager
Post by roadkingrich »
Hi ghostler. How are you able to drive both calipers from the master cylinder without a splitter? I see you were going to let us know how this kit worked out but haven't posted anything since last year about this post. How did that kit work out?
Just for future reference, when it says 86-99, it means 86 thru 99, so everything in between is covered as well. I can see where you'd misunderstand this. Please let me know how this kit worked. I may want one for mine.
A double length banjo bolt will accommodate both lines.
ghostler
Has liked: 3 times
Post by ghostler »
roadkingrich wrote:Hi ghostler. How are you able to drive both calipers from the master cylinder without a splitter? I see you were going to let us know how this kit worked out but haven't posted anything since last year about this post. How did that kit work out?
Yes, worked out fine, fit my 2001. Kit comes with a double banjo bolt, no splitter required, each line runs directly from master cylinder to each caliper. Later I'll post some photos of what I did for info sake.
George Hostler
Clovis, NM, US
1971 Honda CB100
roadkingrich
Sweet! Thank you
morgan21
1
Post by morgan21 »
ghostler wrote: Mon May 04, 2015 7:20 am Trying to find an answer in the forums, must say the search engine is not cooperating. I used the search terms, "rear brake switch problem", and it rejected rear, brake and switch saying words are too common.
This is definitely a tricky situation. It’s frustrating when a small part such as the rear brake light switch is placed in such a hard to reach area. If the mounting bracket is blocking access and there is no other way to remove the switch without taking off the hydraulic lines, then that might be the only option. Some riders choose to replace these pull switches with a banjo bolt pressure switch, which can be more reliable and easier to install if there is enough space above the bolt. It is important to check the thread pitch first. Most Suzuki bikes use a 1.00 millimeter pitch, but it’s always good to confirm before making changes. This kind of upgrade, like installing a hydraulic steering system on a boat, helps improve reliability and makes future maintenance easier.
morgan21;
nice to see an old post get resurrected and commented on.
A banjo bolt pressure switch would certainly make for a much simpler system indeed.
The archives is certainly a treasure of topics.
buzzcut
4
Current bike(s): 2001 zg1200, 1986 zg1000, 1983 gs1100, 1981 cm400a
Been liked: 39 times
Post by buzzcut »
for what its worth, I was having the same trouble and I sprayed some really concentrated degreaser on it repeatedly and worked the pedal. No trouble in over a year but I do spray it once a year now as my spring tuneup. Dont have a name on the degreaser but the sawmills use it and its purple lol. Got some from a millwright.
Has liked: 506 times
triton28 wrote: Wed Apr 23, 2025 6:53 pm nice to see an old post get resurrected and commented on.
Seems to happen around this time of year.
