2015 voyager oxygen sensor
frontspoke
Current bike(s): 2010 Voyager...red/blk...the fastest one!
Post by frontspoke »
my 2015 Voyager has an oxygen sensor in right side muffler...I want to put Cobra slip-ons on the beast but there is no opening in the new slip on for the sensor...my queston is what harm will it do if I disconnect the sensor??? Thanks all
Lucasind
and a bunch of parts !
Has liked: 203 times
Been liked: 72 times
Re: 2015 voyager oxygen sensor
Post by Lucasind »
viewtopic.php?f=18&t=9202" onclick="window.open(this.href);return false;
Not sure if you saw this recent similar post. :-D
Since your machine has fuel injection, disconnecting the sensor will affect performance because the CPU cannot determine how to meter the fuel flow without the oxygen sensor. My advice is to find a machine shop that can bore a hole and tig weld a screw in port on the new exhausts to install the bike's O2 sensor. Try to get it near the same installation point because where you install the sensor is very important to the CPU.
rock42
Current bike(s): 2015 Kawasaki voyager
1995 Harley dyna wide glide
1975 Goldwing
1982 goldwing interstate
Post by rock42 »
just did mine i put on vance and hines slip ons and get a 12mm bung and took it to a muffler shop where they cut a hole and weilded the bung in and now i have the o2 senser hooked up on my 2015 voyager.
rock42
1975 Goldwing
Post by rock42 »
u can find the bung on line
:woohoo:
