Speedometer Error fix
- rustynut51
Take a 1/16 drill bit run slowly down the center of
the roll pin drill all the way through. then you have a center
point to drill back toward the roll pin from back side
using a 9/64 drill bit .
after disassembly and cleaned and new gears in put anti seize
on shoulder of pinion housing . put roll pin back in used a little
black sealant on both ends of roll pin to keep sealed from water.
don't know if this will help anybody that still has to change the gears
in the head yet .
in the head yet .
- rustynut51
Re: Speedometer Error fix
my speedometer was off 10 mph
bought 24t gear was all I could find
now its only off 5 mph . I did find a 23t
gear when I get it installed . speedometer
should be right on . hope this helps depending
how far off your speed is. as to gear you need
- richardb, austin
If it works for you hooray! But FWIW, all my Voyager ZG1200 experience has yielded a speedo that shows at least 10% (15% on one of them) faster than the bike is actually going BUT the odometers (distance traveled) were spot on. So, I left 'em alone, not wanting to chance screwing up the odo in order to have a righteous speedo.
richardb, austin
__________________
__________________
- Current bike(s): 2003 1200
My speedo is a 3-4 mph off when comparing to the gps. That's fine with me. Probably saved a lot of us from getting tickets!
- rustynut51
used my gps to compare to speedometer.
had five miles of flat road . going to do it again
after new gear shows up . hope its closer to right
- rustynut51
my results. got my new 23 tooth gear.
installed ran it with my Gps all lower speeds
are right on. as you go higher the speed is off.
55 is 54 60 is 59 etc. so if your speed is off by
5 mph you need 24 tooth gear if off by 10 mph you
need 23 tooth gear. this is want I had to do for mine .
another bike might be different . hope this helps .
- rustynut51
today rode bike to work 50 miles each way.
worked great kept up with traffic ok speed was good .
even had a state trouper behind me . has to be ok
or he would have stopped me.
- rustynut51
on way home from work yesterday .
cops had radar set up . so I must still be right
for my speed . rode by them with no problems .
if anyone has questions . will try to answer them for you.
- chevyman1
- Been liked: 16 times
FYI
1996 ZX600 has the same drive as the Voyager but with the 23 T gear.
- rustynut51
fits all these . if know somebody that has a junk bike and need the gear for yours
1987 EX500 (EX500-A1) - Front Wheel
1988 EX500 (EX500-A2) - Front Wheel
1988 NINJA 250R (EX250-F2) - Front Wheel
1988 NINJA 600R (ZX600-C1) - Front Wheel
1989 EX500 (EX500-A3) - Front Wheel
1989 NINJA 250R (EX250-F3) - Front Wheel
1989 NINJA 600R (ZX600-C2) - Front Wheel
1990 EX500 (EX500-A4) - Front Wheel
1990 NINJA 250R (EX250-F4) - Front Wheel
1990 NINJA 600R (ZX600-C3) - Front Wheel
1991 EX500 (EX500-A5) - Front Wheel
1991 NINJA 600R (ZX600-C4) - Front Wheel
1992 EX500 (EX500-A6) - Front Wheel
1992 NINJA 250R (EX250-F6) - Front Wheel
1992 NINJA 600R (ZX600-C5) - Front Wheel
1993 EX500 (EX500-A7) - Front Wheel
1993 NINJA 250R (EX250-F7) - Front Wheel
1993 NINJA 600R (ZX600-C6) - Front Wheel
1994 NINJA 250R (EX250-F8) - Front Wheel
1994 NINJA 600R (ZX600-C7) - Front Wheel
1995 NINJA 250R (EX250-F9) - Front Wheel
1995 NINJA 600R (ZX600-C8) - Front Wheel
1996 NINJA 250R (EX250-F10) - Front Wheel
1996 NINJA 600R (ZX600-C9) - Front Wheel
1997 NINJA 250R (EX250-F11) - Front Wheel
1997 NINJA 600R (ZX600-C10) - Front Wheel
1998 NINJA 250R (EX250-F12) - Front Wheel
1999 NINJA 250R (EX250-F13) - Front Wheel
2000 NINJA 250R (EX250-F14) - Front Wheel
2001 NINJA 250R (EX250-F15) - Front Wheel
2002 NINJA 250R (EX250-F16) - Front Wheel
2003 NINJA 250R (EX250-F17) - Front Wheel
2004 NINJA 250R (EX250-F18) - Front Wheel
2005 NINJA 250R (EX250-F19) - Front Wheel
2006 NINJA 250R (EX250F6F) - Front Wheel
2007 NINJA 250R (EX250F7F) - Front Wheel
hope this helps
hope this helps
- rustynut51
- kjsett
Bike in Storage????????rustynut51 wrote:have had no problems with the new gear. or with the police . so must be right on speed I travel on the highway. no trooper problems. bike in storage till spring now . hope everybody has a good holiday season coming up.
Yesterday the wife and I rode to work (she on her 97 Vulcan 800), then on to a movie at 4pm and home at 6:30pm. Temps were:
65F
82F
75F
Ears got a little cool at 65F (half helmet), but otherwise very pleasant riding day.
Enjoy your Winter (we will).
Ken
- rustynut51
- Has liked: 890 times
- Been liked: 313 times
It was nice in NE Ohio today.
Peg and I rode ours to church,[10miles],than to visit our daughter and family[70miles].The temps for the day were 55-63.
- rustynut51
2005 Kawasaki Concours
- Been liked: 5 times
Thanks very much for posting this. Just rebuilt a used speedo gear with the 23t gear. Finally have an accurate speedometer.rustynut51 wrote:Take a 1/16 drill bit run slowly down the center of
in the head yet .
- rustynut51
Wait....what?? Are you saying that all these speedo hubs listed will work as-is on out XII's, or just that they have 23t gears in them? If the possibility exists that one of these listed speedo hubs can just be swapped-out with ours, I'm all-in for that one! MUCH less work for the mechanic!rustynut51 wrote:fits all these . if know somebody that has a junk bike and need the gear for yours
hope this helps
Anybody know?
- chevyman1
Yes ,and you can find them on ebay for cheep
