Fairing Plastic- Repair Needed
- RDW-B14
- Current bike(s): '12 KLR 650
'00 Voyager Xll -- For SALE!! - Has liked: 0
Just got a 2000 12 and found 3 fairing screw locations to be broken. They'd been glued before. I'd like to know what type of plastic is the fairing and what glue has been found to work the best.
Thanks for any info. you have to share!
Take care, RD
Take care, RD
If one rides as one lives, would one be in the ditch?
'12 KLR 650
'12 KLR 650
Re: Fairing Plastic- Repair Needed
All the body plastic parts on the Voyager XII are constructed of ABS plastic. You can find ABS glue at a plumbing supply house. Good luck. If you need to replace any parts and dont mind repainting, contact Carl Leo who has some plastic pieces in stock. You can email him at voyagerparts@bellsouth.net. Leave a phone number so he can call you back.
- RDW-B14
Thank you, Sir, for the info. and help! Much appreciated!
Take care, RD
Take care, RD
'12 KLR 650
'12 KLR 650
You can also search ebay for body parts going to ebaymotors/Kawasaki Voyager XII or 1200/parts.
- Been liked: 249 times
Several of the screw holes are busted out on my fairing lowers, and on the upper fairing, where they attach to it, from flex stress. Something is out of line, and I am unable to figure out what it is.
I tried re-gluing them with ABS Glue (ABS plastic suspended in a solvent: when the solvent evaporates, the ABS is left behind, solid). The glue worked, but it did not last long as the stress was still present -- it broke again, in the identical manner, and location.
Solution: I use Zip-ties to hold the lowers in place. There is one screw, I think, which is still in place. The other two holes are held in position with nylon Zip-ties. They work wonderfully, without putting the stress into the remainder of the lowers -- they have not broken further in the nine years that I've done this. I use black Zip-ties, which are only noticeable if you look for them, up close. I pull them tight, and then I cut off the remainder of the tie, snug against the lock, so they are very difficult to spot, visually.
When I need to remove the lowers, I use a pair of wire side-cutters to remove the Zip-ties (cheap, so I don't mind replacing them, as needed). I've put over 8,000 miles on the bike, with the lowers being held in place with Zip-ties: no issues yet. It sounds terrible, but it works just fine, and no one is the wiser, except me. I carry spare Zip-ties in the bike, just in case, but I've never had one break on me, yet. Cheers!
- cbrfxr67
- Current bike(s): ZG1200 '99
- Has liked: 3 times
On my gsxr i had a couple tabs break on the tank cover and tried an Astro 7600 Hot Staple Gun (easy to find on amazon). There are a few different versions of this but the staples melt into the fairing and provide extra strength. I did it from the back side and clipped the extra length. This was a high stress point so I used a bit of epoxy in the area too. It held until I sold the bike.
Definitely going to use this on any similar repairs. Just my .02
- RDW-B14
Thanks for the more ideas!
So far I've got the J-B weld for ABS and some acetone to clean with after I grind off the chunks of glue from the last effort that didn't work. Next step, if needed, will probably be the zips.
Take care, RD
Take care, RD
'12 KLR 650
'12 KLR 650
- Has liked: 890 times
- Been liked: 313 times
On the GS1100GK I had before the VXII,I had stress failures on the fairing
.I did what I had to in order to neutralize the stress by bending mounting brackets or enlarging fairing holes.To find where the stress was, I looked for misalignment of mounting and fairing holes,and corrected them.
After I got the holes lined up I was able to quit gluing the fairing back together!
- chevyman1
- Been liked: 16 times
The lower holes on the lower fairing that screw fast to the crash bars that brake, I have a fix for them .
It is a insert and a stainless steel screw no glue just bolt on.
I will have some at the Rally
