Steering bearing servicing with pics
- ewilberg
- Current bike(s): 2011 Vulcan Voyager 1700 ABS
Re: Steering bearing servicing with pics
Ok so I am sorry if this is not the right place to ask but it sure looks like it... So I have the 40mph front wheel wobble. So do I need to take it apart and grease it or just snug that steering head nut?
Eric
Eric
Thanks,
Crash
Crash
- Current bike(s): 2013 Voyager
Hey Ericewilberg wrote:Ok so I am sorry if this is not the right place to ask but it sure looks like it... So I have the 40mph front wheel wobble. So do I need to take it apart and grease it or just snug that steering head nut?
Eric
I replaced my steering head bearings with alls balls these are the tapered bearing like in the older Nomads. Wobble went away. Some folks indicate that the wobble starts with the MCII tires however, I think the roller bearing was a bad idea as there is no support for the bearing against a taper. Just my opinion.
John
PS like the pics on the site you do not have to take the fairing off...just be slow and careful
John
2013 Voyager.
2013 Voyager.
- Current bike(s): 2013 Kawasaki Vulcan Voyager 1700
Thanks for the pics and information, I had a shimmy in the front end and couldn't take my hand off the wheel, took the bearings out cleaned them up, regreased and re installed, tightened down now I can ride without any hands if I so choose.
- Current bike(s): 2011 Kawasaki Voyager 1700 Abs.
2001 Yamaha Vstar 650 - Has liked: 0
I know this is an old thread but this is so much help. I've had a shimmy / vibration on my 2011 Voyager that I have not been able to locate the root cause.
I guess I will be doing All Ball tapered bearings soon. Glad to see that I might get away without removing the fairing.
Thank you.
Thank you.
- Current bike(s): 2010 Kawasaki Vulcan Voyager 1700
The Pictures are gone!
AudiDoc?
![Crying :cry2:](./images/smilies/crying2.gif)
AudiDoc?
![Help :help:](./images/smilies/help.gif)
When you find yourself on the side of the majority, it's time to pause and reflect.
- Current bike(s): 2016 Voyager
Gentlemen,
Appreciate any recommendations ... breaking down to adjust the front steering stem bearing and having a heck of a time finding a compatible socket for the Steering Stem Head Nut. "Periodic Maintenance 2-39 in manual. Removing the nut will allow removal of the Steering Stem Head.
I believe it is a 38MM nut but most sockets are too thick to get around the nut.
Is there such a thing as a thin walled 38 mm socket??
Have a 2016 Vulcan Voyager... 50 K miles.
Thanks in advance...
R.C.
R.C.
The socket for my 2012 Voyager is 36mm Craftsman. I'm attaching three pictures of the tools I use to adjust the preload on the steering stem. But while your that far into the steering grease the bearings.
After you remove the upper triple clamp you'll see a castle nut (this is the nut you adjust to take the free play out of the steering head.) Lift the front of the motorcycle enough to expose the lower steering head bearing to apply grease. Then lower the motorcycle back down and reinstall the upper bearing and cap. Start torquing the bearings, slowly. Work the handlebars bach and forth many, many times. Then torque again. Keep doing this until you take all of the free play out of the bearings.
- Has liked: 30 times
- Been liked: 134 times
Hello from NJ. Don, I have not made any up for quite a while. I have only two for the 1700's and just found one 1200 for a member that asked a few weeks ago. You would not recognize the shop. It has been all changed for more room to work around the lift. I am almost done with it, it has taken a few months to move everything execpt the lathe and mill to get things organized. I have not been online here for a while. Issues with my parents and been busy with Great Grandchildren. I still can't get used to being a greatgrandfather....
I will start on a new batch of 1200 sockets soon.
- cushman eagle (Tue Apr 26, 2022 10:11 pm)
- Rating: 12.5%
- Has liked: 818 times
- Been liked: 274 times
Hi,Gene,it is good to see you on-line againekap1200 wrote: ↑Tue Apr 26, 2022 11:41 am Hello from NJ. Don, I have not made any up for quite a while. I have only two for the 1700's and just found one 1200 for a member that asked a few weeks ago. You would not recognize the shop. It has been all changed for more room to work around the lift. I am almost done with it, it has taken a few months to move everything execpt the lathe and mill to get things organized. I have not been online here for a while. Issues with my parents and been busy with Great Grandchildren. I still can't get used to being a greatgrandfather....
![Woohoo :woohoo:](./images/smilies/woohoo.gif)
At this point,I do not know of any great grandkids coming soon.
![hmmmm :hmm:](./images/smilies/scratchchin.gif)
I hope we can find a way to meet up this year
![Thumbs Up :thmup:](./images/smilies/thumbup.gif)
