Where do hoses go
grumpy72
99 shadow 1100
93 voyager 1200
Been liked: 15 times
Where do hoses go
Post by grumpy72 »
84 voyager. I removed the tank. Here is what i found.back left corner of rank a fuel line from somewhere about 5/16 fits over that.petcock has a couple of large diameter hoses clamped on.one disappears somewhere i guess hooked to a throttle body.so there are 3 throttle bodies and each one has a separate line from it to the tank? One large line,about 1/2 inch diameter goes from petcock T underand across frame toward right side of bike and it had a fuel filter hanging in the breeze.so goes to nowhere, from petcock to nowhere.seems like it should be to a throttle body somewher.last question when i turn throttle grip the cable goes to a place like a throttle body and i see the mechanism turning.so is that the only cable to throttle body connection? The rubber line to nowhere makes no sense
Me Again
Been liked: 262 times
Re: Where do hoses go
Post by Me Again »
Not sure if this is going to work but at least I have to try
You may have to sign up for kz1300.com
https://www.kz1300.com/modules/ServiceM ... 300SMS.pdf
grumpy72
99 shadow 1100
93 voyager 1200
Post by grumpy72 »
I tied 15 times to sign up.it keeps saying not activated.they never sent an activation email and there is no Contact Us tab
Me Again
Post by Me Again »
grumpy72 wrote: Wed Apr 27, 2022 2:37 pm 84 voyager. I removed the tank. Here is what i found.back left corner of rank a fuel line from somewhere about 5/16 fits over that.petcock has a couple of large diameter hoses clamped on.one disappears somewhere i guess hooked to a throttle body.so there are 3 throttle bodies and each one has a separate line from it to the tank? One large line,about 1/2 inch diameter goes from petcock T underand across frame toward right side of bike and it had a fuel filter hanging in the breeze.so goes to nowhere, from petcock to nowhere.seems like it should be to a throttle body somewher.last question when i turn throttle grip the cable goes to a place like a throttle body and i see the mechanism turning.so is that the only cable to throttle body connection? The rubber line to nowhere makes no sense
Hope this is readable
grumpy72
99 shadow 1100
93 voyager 1200
Post by grumpy72 »
I appreciate the effort but it isnt readable.where can i find this and i will look at it myself,maybe turn it straight and enlarge it
Me Again
Post by Me Again »
grumpy72 wrote: Sun May 01, 2022 7:53 am I appreciate the effort but it isnt readable.where can i find this and i will look at it myself, maybe turn it straight and enlarge it
Unfortunately that is from the manual you could not download .
There is a supplement manual on ebay for 10 bucks though
grumpy72
99 shadow 1100
93 voyager 1200
Post by grumpy72 »
Thank you
Me Again
Post by Me Again »
Not having any luck finding downloads for the free manuals but here are two good alternatives
Both are downloads and you can't knock the price
good luck
https://www.ebay.com/itm/274950954870?c ... rHEALw_wcB
https://www.ebay.com/itm/273723636789?h ... SwJoxccJiD
grumpy72
99 shadow 1100
93 voyager 1200
Post by grumpy72 »
Ty
grumpy72
99 shadow 1100
93 voyager 1200
Post by grumpy72 »
I finally found the missing connection point.maybe now i can get it going
grumpy72
99 shadow 1100
93 voyager 1200
Post by grumpy72 »
I had removed the inline filter while investigating.on one end the word OUT is there. Does that end go to the line going to throttle bodies or does OUT GO on the top pointing upward to the fuel petcock.called fuel tap here by some people posting.
Me Again
Post by Me Again »
grumpy72 wrote: Tue May 03, 2022 8:36 pm I had removed the inline filter while investigating.on one end the word OUT is there. Does that end go to the line going to throttle bodies or does OUT GO on the top pointing upward to the fuel petcock.called fuel tap here by some people posting.
The line goes from the petcock (fuel tap) to the filter. From the filter to the pump (that line has different size inlet/outlet)/
From the pump to the injector pipe (distributing tube). From the tube too the pressure regulator, from the regulator to the check valve at the rear of the tank.
cushman eagle (Wed May 04, 2022 10:31 pm)
grumpy72
99 shadow 1100
93 voyager 1200
Post by grumpy72 »
thank you.its very heloful
