Pilot jet question
Chris Cochran
2006 Vulcan 750
Has liked: 61 times
Been liked: 58 times
Pilot jet question
Post by Chris Cochran »
Ok, I see where I am told to punch a hole in the existing pilot jet plug to remove it.
Then, when re-assembling it says "Install a new plug in the pilot screw hole, and apply a small amount of a bonding agent to the circumference of the plug to fix the plug".
So, my question is: Why re-plug it? I am interpreting this re-plugging statement to be ritualistic legalese speak to make the EPA happy.
Has liked: 242 times
Been liked: 631 times
Re: Pilot jet question
Mine were unplugged when I got it and still are.
Note that this is very difficult to adjust when on the bike. Those normal special tools don't work on these bikes -- too little clearance. I fabricated a tiny tool (by grinding on an L-shaped allen), and I carry it on the road to accommodate big elevation changes on long trips. But you don't really need it, unless maybe going to Peru. (My bike definitely didn't like low RPMs at 12k ft, even though I originally set the pilots for 8k where I live.) But honestly, I've only messed with it a few times on the road.
If the carbs are off, I recommend (gently) bottoming the pilots and then using a Dremel to mark where the slot lines up. With a dentist's mirror, you can keep track of changes without bottoming again like you're really supposed to. I adjust a quarter turn, and then check that all jets really are the same. Repeat as necessary.
Chris Cochran (Sun Jul 31, 2022 3:49 pm)
Chris Cochran
2006 Vulcan 750
Has liked: 61 times
Ok, I'm having problems posting the pictures that I want. I drag a given pic over to post and yet a different pic shows up. Let me try this again.
Incidentally, all the plugs were in mine (don't know if original or not). Carbs #1 and 2 the pilot jets were roughly two turns out. But carb #3 was bottomed out completely and #4 was only 1/4 turn from bottom. Weird.
Anyway, my current conundrum is that the replacement pilot jets are longer than the originals by quite a bit. When installed and given the two turns out, the top comes out higher than the boss.
Is this going to be a problem or should I just clean and replace with original jets?
Chris Cochran
2006 Vulcan 750
Has liked: 61 times
I'm going to use them. The tips are the same, the replacements are just longer on the back end.
