Kawasaki voyager rear tire air pressure check
- Current bike(s): 2016 Kawasaki voyager
I'm new to the forum and I'm thinking of getting a new voyager. The reviews I've read have been pretty good. My question is looking at the bike at the dealership the rear tire looks hard to get to for checking and adding air. Is this a big deal or am I dreaming? Can anyone give me any thoughts on how you do it? Or any rider input on the bike overall, thanks
- Current bike(s): 2010 Kawasaki 1700 Voyager
Re: Kawasaki voyager rear tire air pressure check
It is a bit of a pain to get to. I have to move the bike back and forth until the tire stem is right at the bottom. My bike has the right-angle stem so it's not difficult to use once I get it properly positioned. If you don't have the 90-degree stem, you might want to get one. I wish I had one for the front tire but I've been too lazy to make the switch and besides it is much easier to position.
1975 Goldwing (found a good home for it)
2003 Nomad 1500 (traded for the Voyager)
Thanks, yeah it looks like kind of a tight spot. My dealer suggested the 90 degree valve stem
after talking to some voyager owners some have said there bikes came with the angle valve,stem on the rear from the factory does,anyone know if this is true on the 2016 year?
- Been liked: 83 times
I have a 2012 and it came with a 90 degree stem on the rear. I've also got a spare wheel from a 2009 Voyager and it also came with a 90 degree stem.
Checking the air on the rear is simple but it does require you to get down on you hands and knees.
c
c
- Current bike(s): 2013 Voyager
I have a 2013 Voyager. It has a 90 degree valve stem in the rear. While it's not cheap, I use the Garmin Zumo 390LM with TPMS to check the tire pressure. Makes it real easy. I have checked the accuracy against a good digital tire pressure gauge and it's on the money. Something to consider.
- Current bike(s): 2015 Kawasaki voyager
1995 Harley dyna wide glide
1975 Goldwing
1982 goldwing interstate - Has liked: 0
i have a 2015 and it came with a 90 angle as well also i bought a tire pressure monitoring system (tpms) i helps me from having to check the tire as often, which is not to say i dont check them but laying on my back at 73 yrs old on a cold garage floor is not something i look forward to.
