Greetings All!
I am new to the Voyager world, but have owned other bikes for a long time. I am also a member of the Etowah River Chapter of Southern Cruisers here in GA. Any way, I picked up a 96 out in Great Falls MT and rode it back, and I must say it was a great trip! I have been cleaning and fixing little things on the Voy since I've been back, and I want to address the temp gauge, but don't want to tear apart more than I have too.
What is the best way to get to the area needed, under the battery tray?
Thank you in advance for your help!
Fixing the Temp Gauge Ground
- viper
- Current bike(s): 1999 Kawasaki Voyager XII
Re: Fixing the Temp Gauge Ground
You're almost there...remove the battery and tray and the ground for the temperature guage is i plain view. Usually, by simply sanding and replacing the wire tighter, it will rectify the problem.
Regards,
Viper
Regards,
Viper
If it is to be, it is up to me. Vince
I did that (above) and then just to be sure i loosened the bracket/bolt on the top of the thermostat housing and inserted an extra ground wire and ran that wire up to a bolt on the frame. Temp gauge works great now.
