I saw something a long time ago and it looked interesting,
a way to clear / clean out a fork seal. It's a thin piece'a
plastic with a hooked end that you work down into the seal,
move it around and clear out whatever is lodged in the seal,
causing it to leak...
I just got back from a long trip, saw some oil spots on the
floor, checked around and my right front seal blew and I
had oil all over the fork.... and down the tube...
I used this thing, went for a ride today and the damn
fork is CLEAN!!!! Yeah, I have an unbalanced fork, I'm
gonna put new seals in anyway when I can, I wanted an
excuse to put in Progressive springs, and here it is,
but I now have time to do it!!! Just a FYI
http://www.sealmate.net is the addy on the tool.... and how to use it... best to Ya!!!
Quick fix for leaking fork seals.
Re: Quick fix for leaking fork seals.
Yes it really does work. I used it on mine a couple weeks ago. You have to pump the forks several times to get it to reseal but it does work.
... riding on most KalEfornYa roads will pump the $)%*@$#%* outta your forks!!! GBG
Glad someone else found 'um!!!
- Thud300
1998 Kawasaki Concours
You can make a homemade seal cleaning tool by cutting a piece of plastic milk jug in the rough hook shape of a seal-mate.
1991 Voyager XII "Xaviera"
1989 454 LTD "Merlin"
... good info! Thanks!!!!!
