(I seem to be monopolizing the board )
Anyone know if Clutch and Throttle cables are available for an 86 ZN1300? I assume all models of ZN share the same cables? Also assuming new OEM cables are no longer avaible (with the exception of the odd set on Ebay). Is the only option Motion Pro?
Source for Throttle and Clutch Cables
- Van Voyager
- Has liked: 46 times
- Been liked: 40 times
- Lucasind
- Has liked: 194 times
- Been liked: 69 times
Re: Source for Throttle and Clutch Cables
http://www.ebay.com/itm/NOS-Kawasaki-Ca ... sW&vxp=mtr
There are currently more new one ....and used ones on ebay than you could use in a lifetime !
- trikebldr
'82 Kawasaki KZ1100D Spectre
'79 Vetter Terraplane sidecar
'85 Kawasaki Voyager 1300
The later models have cruise control and use different throttle cables than non-cruise models. I thought the '86 model year was when they started adding cruise control, but maybe not.
- Van Voyager
I believe crusie was added in 87 & 88 models, no?
On a related question, it is possible to retrofit a factory cruise to a model that didn't come with it. I know the instrument cluster is slightly different (Cruise indicator), there's some kind of servo, some handlebar switches, different cables, different wiring harness.... Is the ECU different or are the cruise 'smarts' self contained?
- Me Again
- Been liked: 262 times
I am sure it would be possible to retrofit one but probably much easier to install a universal one .
I put one for an 80's ford in my first 1300 and have one sitting here awaiting installation now .
my problem is that my joints will not allow me to reach around and hook up some of the cables and wires needed ,so it may never get done .
The one I used tied into a coil and worked flawlessly .
