The straight Schrader Valve that a PO installed at the last rear tire change is proving to be a real pain in the ass. I can't find a local source that has an air chuck that will fit on the valve as the tip is too close to the hub of the wheel. I'm thinking the valve should be either a lot shorter or have a right angle bend. I've purchased a right angle schrader valve adapter but it didn't last even one use as it broke the first time I put the chuck to it - I need to find a better quality one.
In order to be prepared for the next tire change, I'd like to order a valve that has the right angle bend - does anyone happen to know the size details for the valve I need to order?
Rear Wheel Schrader Valve.
- Van Voyager
- Has liked: 52 times
- Been liked: 44 times
- Bulrid8
- Current bike(s): 1986 Voyager xii
Re: Rear Wheel Schrader Valve.
You can order brass 90's on Amazon. They work perfect and last. Just screw on to existing valve.
- Van Voyager
I tried one of those. First application of the air hose broke the adapter in half. In any case, I'm looking for a more permanent solution - a 90 degree valve stem - but they appear to come in different sizes to fit different sized rim holes and I don't know the size of the hole on the kawi rim.Bulrid8 wrote:You can order brass 90's on Amazon. They work perfect and last. Just screw on to existing valve.
- Has liked: 119 times
I believe a 90* valve stem from a ZG1200 Voyager, part # 16126-1191will solve your problem.
- Van Voyager
Thanks for the tip Dave.triton28 wrote:I believe a 90* valve stem from a ZG1200 Voyager, part # 16126-1191will solve your problem.
Edit: Just looked at the parts fiche for the ZG: like the ZN, the wheel valve stems are not shown on the fiche.
- Van Voyager
Just an update - the valve stems are shown on the tire fiche (not the wheel fiche).
- Van Voyager
Ended up purchasing a 90 degree valve stem for VN1500 (PART# 16126-1191). Can't remember how I figured that out but it's exactly what I needed. It'll be so much more fun being able to put air in my tires
I just need to be careful not to break the valve stem off:shock: .
EDIT: Figured out how I figured it out: it was the tip from Dave - the same tire valve fits the following models:
- This Kawasaki 16126-1191 VALVE,TIRE fits the following models and components:
Kawasaki Motorcycle 1987 Voyager XII - ZG1200-B1 TIRE
Kawasaki Motorcycle 1987 Vulcan 88 - VN1500-A1 TIRE
Kawasaki Motorcycle 1988 Vulcan 88 - VN1500-A2 TIRE
Kawasaki Motorcycle 1988 Voyager XII - ZG1200-B2 TIRE
Kawasaki Motorcycle 1989 Concours (Canada Only) - ZG1000-A4 TIRE
Kawasaki Motorcycle 1989 Voyager XII - ZG1200-B3 TIRE
Kawasaki Motorcycle 1991 Voyager XII - ZG1200-B5 TIRE
Kawasaki Motorcycle 1991 Vulcan 88 - VN1500-A5 TIRE
Kawasaki Motorcycle 1990 Vulcan 88 - VN1500-A4 TIRE
Kawasaki Motorcycle 1990 Voyager XII - ZG1200-B4 TIRE
Kawasaki Motorcycle 1991 Concours - ZG1000-A6 TIRE
Kawasaki Motorcycle 1989 Vulcan 88 - VN1500-A3 TIRE
Kawasaki Motorcycle 1990 Concours - ZG1000-A5 TIRE
Kawasaki Motorcycle 1999 Voyager XII - ZG1200-B13 Tires
Kawasaki Motorcycle 1999 Vulcan 1500 Nomad - VN1500-G1 Tires
Kawasaki Motorcycle 1999 Vulcan 1500 Nomad - VN1500-G1A Tires
Kawasaki Motorcycle 1999 Vulcan 1500 - VN1500-A13 Tires
Kawasaki Motorcycle 2001 Vulcan 1500 Nomad Fi - VN1500-L2 Tires
Kawasaki Motorcycle 2001 Vulcan 1500 Nomad - VN1500-G3 Tires
Kawasaki Motorcycle 2001 Voyager XII - ZG1200-B15 Tires
Kawasaki Motorcycle 2000 Voyager XII - ZG1200-B14 Tires
Kawasaki Motorcycle 2000 Vulcan 1500 Nomad Fi - VN1500-L1 Tires
Kawasaki Motorcycle 2000 Vulcan 1500 Nomad - VN1500-G2A Tires
Kawasaki Motorcycle 1998 Voyager XII - ZG1200-B12 Tires
Kawasaki Motorcycle 1998 Vulcan 1500 - VN1500-A12 Tires
Kawasaki Motorcycle 1995 Vulcan 88 - VN1500-A9 Tires
Kawasaki Motorcycle 1995 Voyager XII - ZG1200-B9 Tires
Kawasaki Motorcycle 1997 Voyager XII - ZG1200-B11 Tires
Kawasaki Motorcycle 1997 Vulcan 1500 - VN1500-A11 Tires
Kawasaki Motorcycle 1996 Voyager XII - ZG1200-B10 Tires
Kawasaki Motorcycle 1996 Vulcan 1500 - VN1500-A10 Tires
Kawasaki Motorcycle 1994 Vulcan 88 - VN1500-A8 Tires
Kawasaki Motorcycle 1994 Voyager XII - ZG1200-B8 Tires
Kawasaki Motorcycle 1988 Concours - ZG1000-A3 Tires
Kawasaki Motorcycle 1987 Concours - ZG1000-A2 Tires
Kawasaki Motorcycle 1986 Concours - ZG1000-A1 Tires
Kawasaki Motorcycle 2004 Vulcan 1500 Nomad Fi - VN1500-L5 Tires
Kawasaki Motorcycle 2004 Vulcan 1600 Mean Streak - VN1600-B1 Tires
Kawasaki Motorcycle 2003 Voyager XII - ZG1200-B17 Tires
Kawasaki Motorcycle 2003 Vulcan 1500 Mean Streak - VN1500-P2 Tires
Kawasaki Motorcycle 2003 Vulcan 1500 Nomad Fi - VN1500-L4 Tires
Kawasaki Motorcycle 2002 Voyager XII - ZG1200-B16 Tires
Kawasaki Motorcycle 2002 Vulcan 1500 Nomad Fi - VN1500-L3 Tires
Kawasaki Motorcycle 2002 Vulcan 1500 Mean Streak - VN1500-P1 Tires
Kawasaki Motorcycle 2008 Vulcan 1600 Mean Streak - VN1600B8FA Tires
Kawasaki Motorcycle 2008 Vulcan 1600 Mean Streak - VN1600B8F Tires
Kawasaki Motorcycle 2007 Vulcan 1600 Mean Streak - VN1600B7FA Tires
Kawasaki Motorcycle 2007 Vulcan 1600 Mean Streak - VN1600B7F Tires
Kawasaki Motorcycle 2006 Vulcan 1600 Mean Streak - VN1600F6F Tires
Kawasaki Motorcycle 2006 Vulcan 1600 Mean Streak - VN1600B6F Tires
Kawasaki Motorcycle 2005 Vulcan 1600 Mean Streak - VN1600-B2 Tires
Kawasaki Motorcycle 1993 Concours - ZG1000-A8 Tires
Kawasaki Motorcycle 1992 Vulcan 88 - VN1500-A6 Tires
Kawasaki Motorcycle 1992 Voyager XII - ZG1200-B6 Tires
Kawasaki Motorcycle 1993 Vulcan 88 - VN1500-A7 Tires
Kawasaki Motorcycle 1993 Voyager XII - ZG1200-B7 Tires
Kawasaki Motorcycle 1992 Concours - ZG1000-A7 Tires
