Hi folks. Just picked up a 1991 XII. I've done some of the basic maintenance stuff and am enjoying being back on two wheels. I didn't like the foam grips on it though. So I purchased a pair that were said to fit. I removed the foamy from the clutch side and and slipped the new one one to test fit. It's 1/2" to short! There's a gap between the inward end of the grip and the radio control assembly. Seems they listed the "overall" length (5 7/8") which included a screw-on end cap but didn't account for the fact that the grip end was closed so it bumps up to the bar end plug.
All that to ask if there's a recommendation for a grip that will fit without cutting off the end plugs?
yustr
New (to me) 1200 - Grip Replacement
Re: New (to me) 1200 - Grip Replacement
... first thing I'd look at is cutting a hole in the grip end so the end grip
would slide through the hole....
- 6
- Current bike(s): 1991 Voyager XII
Thanks for the suggestion cranky but the end is pretty stout metal. Plus, I doubt I could ream/drill an opening to clear the bar (7/8") and not interfere with the 4 screws that attach the end cap.
Here's a link: https://www.amazon.com/dp/B0783J5BZD/re ... 05866&sr=3
- Bulrid8
- 6
- Current bike(s): 1986 Voyager xii
I just cut a 1/2" off end of bars. I am not putting weights back on. I like them this way.
Thanks for the pic!!!! Had no real idea what you had, just wanted to put some
different thoughts out to think about. Best to Ya!!!!!
yustr wrote:Thanks for the suggestion cranky but the end is pretty stout metal. Plus, I doubt I could ream/drill an opening to clear the bar (7/8") and not interfere with the 4 screws that attach the end cap.
- 6
Decided to follow this path. Bar ends came off easily with my angle grinder and the grips slipped right on with no issues. Used an old golf club fitter's trick and used ordinary rubber cement to secure the clutch side grip.Bulrid8 wrote:I just cut a 1/2" off end of bars. I am not putting weights back on. I like them this way.
It's a sunny day here in the Pacific NW so am going for a ride right after lunch.
I cut a half inch off both bars using a die grinder. Then I just reattached the bar ends. The new grips were chrome so I painted the bar ends silver.
