Turn Signal Cancel
RDW-B14
Current bike(s): '12 KLR 650
'00 Voyager Xll -- For SALE!!
Turn Signal Cancel
Post by RDW-B14 »
Is there a way to disable the automatic turn signal canceler? I want to turn them on AND off manually! Is there a wire to unplug?
Many thanks! Take care, RD
If one rides as one lives, would one be in the ditch?
'12 KLR 650
Has liked: 109 times
Been liked: 281 times
Re: Turn Signal Cancel
You have what a lot of owners would like to have: a working turn signal cancel system. However, if you wish to disconnect it there is a connector on a short harness coming from the actual turn signal cancel unit which can be disconnected from the main harness connector. The turn signal cancel unit is located behind the LH upper cowling, stacked with the reserve lighting device. There is a youtube video by Igozum, ( I believe that is the name ), about removing the cowling(fairing) that may be of some help to you.
Van Voyager
Has liked: 46 times
Been liked: 40 times
Post by Van Voyager »
Can't you just turn them off manually even when they're still in automatic mode?
RDW-B14
Post by RDW-B14 »
Thanks for the helpful info. I'll be checking into doing the disconnect.
Yes, the signal can be shut-off manually. But my problem is it shuts-off too soon. I turn it on when I want it on and it shuts-off before I get to the turn. I want to have control when it's on and off.
Thanks for the replies! Take care, RD
'12 KLR 650
... believe one of our vendors on the classifieds sell extensions for the turn
duration....
Van Voyager
Has liked: 46 times
RDW-B14 wrote: Wed Jun 12, 2019 12:41 am Yes, the signal can be shut-off manually. But my problem is it shuts-off too soon. I turn it on when I want it on and it shuts-off before I get to the turn. I want to have control when it's on and off.
Ahh, makes sense. On my ZN1300, there's a switch to disable the automatic cancel.
RDW-B14
Post by RDW-B14 »
I'm not wanting to get out of the habit of canceling the signal myself, so when I ride a non-automatic canceler (like my KLR), I won't be so likely to forget to cancel the signal.
Take care, RD
'12 KLR 650
Has liked: 858 times
RDW-B14 wrote: Sat Jun 15, 2019 1:17 am I'm not wanting to get out of the habit of canceling the signal myself, so when I ride a non-automatic canceler (like my KLR), I won't be so likely to forget to cancel the signal.
Take care, RD
I drive truck part time,and non of our heavy trucks have auto-signal cancel,which helps me to remember to cancel.I still like it on my bike. :thmup:
Right now in the AVA Classifieds there is for $20 a turn signal blinker extender.
RDW-B14
Post by RDW-B14 »
Thanks! That'd be great for those wanting self canceling signals. But I want myself canceling signals.
Take care, RD
'12 KLR 650
If you extend the blinker time you get to cancel yourself.
I make the cancel extenders, they are adjustable .
I will have some at the Rally
:thmup:
Thud300
1998 Kawasaki Concours
1989 Kawasaki 454 LTD
Post by Thud300 »
Details please? I like the auto cancel but would like to add a few seconds to the on time.
1991 Voyager XII "Xaviera"
1989 454 LTD "Merlin"
The way the cancel system works is when you engage the turn signal a signal is sent to the cancel control box, the box counts four seconds then it switches over to the speedometer at that point it is now counting distance I think around 50 ft.
The turn signal cancel extender delays the signal to the cancel control from 1 to 5 sec. and it totally plug and play.
They are $25.00 + $7.00 shipping
:thmup:
