Cruise control
ted1r
1
Has liked: 100 times
Been liked: 38 times
Cruise control
Post by ted1r »
Hi Guys ,just a quick question .whilst out the other night I was on a four lane section of road doing about 70mph at which point I tried the cruise
which abruptly brought me down 55 :tho: Is this normal ?no end of fiddling would increase the speed,
any help guys
Ted
Been liked: 249 times
Re: Cruise control
Check the cable tension in the actuator. There are videos for this adjustment on YouTube, along with threads here on it.
If the cable tension is not the solution, then it might be an actuator/control box issue. Start with the simple/easy, and work towards the complex/expensive end of the spectrum. Cheers!
:thmup:
cushman eagle (Mon Apr 01, 2024 7:13 pm) • ted1r (Tue Apr 09, 2024 11:36 am) • Stew (Tue Apr 09, 2024 1:47 pm)
Rating: 33.33%
ted1r
1
Re: Cruise control
Post by ted1r »
MANY THANKS SIR
TED
Re: Cruise control
You are most welcome.
The actuator cable tension slips, over time. This is the usual suspect, and it is not too difficult to adjust. It makes a world of difference, relieving a host of stressors -- I just wish the other life stressors were so easy to relieve! :roll: Cheers!
cushman eagle (Wed Apr 03, 2024 7:31 pm) • ted1r (Fri Apr 05, 2024 8:14 am)
ted1r
1
Re: Cruise control
Post by ted1r »
MANY THANKS ,all sorted after a bit of fiddling :woohoo:
TED
These users liked ted1r's post:
cushman eagle (Tue Apr 09, 2024 5:09 pm)
