compressor guage light goes on in neutral and off in gear
- 1
- Current bike(s): 2000 kawasaki W650 1984 kawasaki Voyager zn1300
compressor light comes on in neutral and off in gear and sometimes stays on it works when light is on is there something connected to the neutral that has to do with the compressor light
- Me Again
- Been liked: 282 times
Re: compressor guage light goes on in neutral and off in gear
Actually, that sounds correct since the pump only works in neutral
- 1
did not know the pump only works in neutral but the light used to stay on and now only on in neutral any ideas
- Me Again
Most lighting issues I have fund come down to dirty/corroded connectors.
Took me about a week to track down a corroded inline fuse when my dash went out last year (lights worked but screen was blank).
- 1
- Van Voyager
- Has liked: 52 times
- Been liked: 44 times
The light should only come on (and the pump work) when you're in neutral (unless they changed that behaviour with 87 & 88 models - if you happen to have one of those). If it didn't work like that in the past, then somebody changed something (which wouldn't be a bad mod IMHO, as it would be handy to be able to adjust pressure while on the move).NightRider1 wrote: ↑Mon Aug 26, 2024 3:11 pm did not know the pump only works in neutral but the light used to stay on and now only on in neutral any ideas
